  4. Another day MyRoute-app screwed up My Route
52 Posts 6 Posters 34.4k Views 2 Watching
  • Ton Machielsen Ton Machielsen
    @Marinus-van-Deudekom
    I get 18…
    On the CarPlay I get none.
    @Ton-Machielsen
    Ahh cause found.
    You've select "start at nearest waypoint" that is Waypoint 18 in your case. Unselect this option and try again.
    Ton Machielsen 2 Replies Last reply
      @M-Schrijver Understand. That’s why I am suggesting a radius for the waypoint hits. If you pass the waypoint within that distance the waypoint is considered as hit.
      @Ton-Machielsen when navigating with the nex app is will go OK. If you would use such a route in lets say an Garmin XT, you would be in great trouble.
      That's why we have and use MRA next
        @Ton-Machielsen
        There is already a radius. But this radius is limited for a reason. Point 7, 11, 12 and 16 on route shows why. It is normal practice that you do your best to place the waypoints on the road.
        • M. Schrijver M. Schrijver
          @Ton-Machielsen
          Ahh cause found.
          Ton Machielsen
          Ton Machielsen
          Ton Machielsen
          This post is deleted!
            @Ton-Machielsen
            Ahh cause found.
            Ton Machielsen
            Ton Machielsen
            Ton Machielsen
            @M-Schrijver Where can I find this setting?
              It is the first option below de "start" button
              • Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                Ha! Never seen that menu before!! Thanks!
                • Ton Machielsen
                  Ton Machielsen
                  Ton Machielsen
                  Any idea why I don’t get the waypoint hand and Skip Waypoint icon on the CarPlay? (see https://forum.myrouteapp.com/post/61333)
                  Remember I am on a bike. I have the phone in my pocket and am navigating through the CarPlay device.
                    @Ton-Machielsen Due to restrictions by Apple and Google the viapoint sign is NOT on Androis Auto and Carplay
                    Ton Machielsen 1 Reply Last reply
                      Something to add to your comment.
                      When waypoints are way off route/road and you're riding a route (not a track). How can MRA Navigation (or other navigation) hit those waypoints when they are not on the road or very close to the road.
                      Those waypoints causes recalculations just because the waypoints are too far off-road.
                      Ton Machielsen
                      Ton Machielsen
                      Ton Machielsen
                      @M-Schrijver Is the “Navigate routes as tracks” option my solution?
                        #31
                        @Ton-Machielsen said in Another day MyRoute-app screwed up My Route:
                        That is a sensible suggestion - agreed, but I suspect the radius must change depending on the circumstances. Roads that are close together will require a smaller radius to be drawn by MRA, so basically, the radius info would just be telling you what you know you need to do anyway - i.e. drop the waypoints 'accurately'! 😁
                          @Ton-Machielsen
                          No. If you want route to be riden reliable. The route itself should be made reliable. A navigation cannot fix a badly made route.
                            @Ton-Machielsen, I guess this thread gives some "food for thought" 😉
                            Great thread, that shows the power of an "old-fashioned" forum! 💪
                              @Ton-Machielsen
                              Ton Machielsen
                              Ton Machielsen
                              Ton Machielsen
                              @M-Schrijver said in Another day MyRoute-app screwed up My Route:
                              @Ton-Machielsen
                              Ok, i'll bite. Define "a badly made route".
                              My take is that if the app shows the route i want to ride, the app should follow that route.
                              What's your take?
                                Ton Machielsen
                                Ton Machielsen
                                Ton Machielsen
                                @Marinus-van-Deudekom said in Another day MyRoute-app screwed up My Route:
                                Meaning the "Skip Waypoint" icon is also not? So how do i skip waypoints? Stopping, taking my gloves off, taking my phone out of my pocket, click "Skip waypoint", dress up and continue?
                                Marinus van Deudekom M. Schrijver 3 Replies Last reply
                                  @Ton-Machielsen yep unfortunately that's the case when using Android Auto or CarPlay.
                                    @Ton-Machielsen
                                    What's your take?
                                    @Ton-Machielsen not completely true. As long as you stay within MRA its by design that MRA will save the day and keep you on the route, even if the route is not made correctly like in your example. However if you wanted to use that same route in a dedicated device like a Garmin XT you would be in for a real bad day with a messed up route.
                                      Ton Machielsen
                                      Ton Machielsen
                                      Ton Machielsen
                                      @Marinus-van-Deudekom Yeah, and that's where i am struggling, apparently. I was assuming that if MyRoute-app drew the correct route, even though my waypoints are besides the road, that the app would prioritise the route over the waypoints. Which is not the case from what i experience and read.
                                      I guess i will have to either be VERY precise in where i put my waypoints or choose another app which is following a route (route app, remember, not waypoint app) instead of waypoints.
                                      • Ton Machielsen
                                        Ton Machielsen
                                        Ton Machielsen
                                        Team!! Thanks for all the suggestions and bearing with my gripes and complaints. I am getting there. I must admit, apart from maybe two or three, all my waypoints were quite far away of the road i was planning to take. I have corrected them and re-uploaded the route here: https://www.myrouteapp.com/en/social/route/10719669 I hope the waypoints are positioned better now.
                                        While doing this i think that a small fix (not being a programmer) could avoid this situation. I plan on the mobile app, not on the computer, and while correcting the waypoints i came up with two improvements:
                                        1. When holding the waypoint and moving it, you can not actually see where you place it because your finger is right on top of the waypoint. And since precision is required, it would be helpful if the waypoint on the screen was a bit offset from the finger on the screen. Unless there are more efficient ways of moving a waypoint, of course.
                                        2. When moving a waypoint, making it snap to the nearest road would be helpful as well. I think that when i double-tap a road a new waypoint is placed on the road. This function would be helpful while moving waypoints as well. Unless there are tricks like double-tap on the road and removing the other one would work as well. Haven't tried that yet.
                                        Ideas?
                                        And yes, again, i am getting there, i hope.
                                        richtea999 Carl Lee 2 Replies Last reply
                                          Ideas?
                                          #40
                                          @Ton-Machielsen
                                          The revised route looks a lot better, Ton. 👍
                                          I still advise you to place the start and end points on roads though, and maybe a few metres in the direction you're intending to set off / arrive from, just to guaranteee you pass through them. Especially the start one. 😉
                                          On the improvements front, they're good suggestions, but here's one for you in the meantime (because they'll not happen fast, if ever):
                                          1. Get a stylus. Something like a basic Wacom one is cheap, pleasant to use, and it's a pen as a bonus:
                                            https://www.amazon.co.uk/Wacom-Universal-Ballpoint-Smartphones-Touchscreen/dp/B07YDX6Y24
                                            Then you can see what you're doing under the stylus tip!
                                          Carl Lee
                                          Carl Lee
                                          Ton Machielsen
                                          Ton Machielsen
                                            Rene van Maanen
                                            Rene van Maanen
                                          • One crash today
                                          • Download club route folders
                                            136
                                            Mosimann
                                            Mosimann
