  4. Another day MyRoute-app screwed up My Route
52 Posts 6 Posters 35.0k Views 2 Watching
  • Ton Machielsen Ton Machielsen
    @Marinus-van-Deudekom
    I get 18…
    On the CarPlay I get none.
    @Ton-Machielsen there you have it. The app is trying to get you to the nearest waypoint, that would be nr 18. Since you know where waypoint 1 is, you've driving towards that waypoint nr 1 and meanwhile the app tries to get you to go to waypoint 18.
    The fact that your waypoints are not ON the route is not good but the aopp will disregard those of route waypoints and try to navigate as close as possible to thoes waypoints. Your problems lies in the fact that you didn't not selct waypoint 1
      Something to add to your comment.
      When waypoints are way off route/road and you're riding a route (not a track). How can MRA Navigation (or other navigation) hit those waypoints when they are not on the road or very close to the road.
      Those waypoints causes recalculations just because the waypoints are too far off-road.
      Ton Machielsen
      Ton Machielsen
      Ton Machielsen
      @M-Schrijver Understand. That’s why I am suggesting a radius for the waypoint hits. If you pass the waypoint within that distance the waypoint is considered as hit.
      Marinus van Deudekom M. Schrijver richtea999 3 Replies Last reply
        I get 18…
        @Ton-Machielsen
        Ahh cause found.
        You've select "start at nearest waypoint" that is Waypoint 18 in your case. Unselect this option and try again.
        Ton Machielsen 2 Replies Last reply
          @Ton-Machielsen when navigating with the nex app is will go OK. If you would use such a route in lets say an Garmin XT, you would be in great trouble.
          That's why we have and use MRA next
            @Ton-Machielsen
            There is already a radius. But this radius is limited for a reason. Point 7, 11, 12 and 16 on route shows why. It is normal practice that you do your best to place the waypoints on the road.
              @Ton-Machielsen
              Ahh cause found.
              Ton Machielsen
              Ton Machielsen
              Ton Machielsen
              This post is deleted!
                @Ton-Machielsen
                Ahh cause found.
                Ton Machielsen
                Ton Machielsen
                Ton Machielsen
                @M-Schrijver Where can I find this setting?
                  It is the first option below de "start" button
                  • Ton Machielsen
                    Ton Machielsen
                    Ton Machielsen
                    Ha! Never seen that menu before!! Thanks!
                    • Ton Machielsen
                      Ton Machielsen
                      Ton Machielsen
                      Any idea why I don’t get the waypoint hand and Skip Waypoint icon on the CarPlay? (see https://forum.myrouteapp.com/post/61333)
                      Remember I am on a bike. I have the phone in my pocket and am navigating through the CarPlay device.
                        @Ton-Machielsen Due to restrictions by Apple and Google the viapoint sign is NOT on Androis Auto and Carplay
                        Ton Machielsen 1 Reply Last reply
                          Ton Machielsen
                          Ton Machielsen
                          Ton Machielsen
                          @M-Schrijver Is the “Navigate routes as tracks” option my solution?
                            #31
                            @Ton-Machielsen said in Another day MyRoute-app screwed up My Route:
                            That is a sensible suggestion - agreed, but I suspect the radius must change depending on the circumstances. Roads that are close together will require a smaller radius to be drawn by MRA, so basically, the radius info would just be telling you what you know you need to do anyway - i.e. drop the waypoints 'accurately'! 😁
                              @Ton-Machielsen
                              No. If you want route to be riden reliable. The route itself should be made reliable. A navigation cannot fix a badly made route.
                                @Ton-Machielsen, I guess this thread gives some "food for thought" 😉
                                Great thread, that shows the power of an "old-fashioned" forum! 💪
                                  @Ton-Machielsen
                                  Ton Machielsen
                                  Ton Machielsen
                                  Ton Machielsen
                                  @M-Schrijver said in Another day MyRoute-app screwed up My Route:
                                  @Ton-Machielsen
                                  Ok, i'll bite. Define "a badly made route".
                                  My take is that if the app shows the route i want to ride, the app should follow that route.
                                  What's your take?
                                    Ton Machielsen
                                    Ton Machielsen
                                    Ton Machielsen
                                    @Marinus-van-Deudekom said in Another day MyRoute-app screwed up My Route:
                                    Meaning the "Skip Waypoint" icon is also not? So how do i skip waypoints? Stopping, taking my gloves off, taking my phone out of my pocket, click "Skip waypoint", dress up and continue?
                                    Marinus van Deudekom M. Schrijver 3 Replies Last reply
                                      @Ton-Machielsen yep unfortunately that's the case when using Android Auto or CarPlay.
                                        @Ton-Machielsen
                                        What's your take?
                                        @Ton-Machielsen not completely true. As long as you stay within MRA its by design that MRA will save the day and keep you on the route, even if the route is not made correctly like in your example. However if you wanted to use that same route in a dedicated device like a Garmin XT you would be in for a real bad day with a messed up route.
                                          Ton Machielsen
                                          Ton Machielsen
                                          Ton Machielsen
                                          @Marinus-van-Deudekom Yeah, and that's where i am struggling, apparently. I was assuming that if MyRoute-app drew the correct route, even though my waypoints are besides the road, that the app would prioritise the route over the waypoints. Which is not the case from what i experience and read.
                                          I guess i will have to either be VERY precise in where i put my waypoints or choose another app which is following a route (route app, remember, not waypoint app) instead of waypoints.
                                          Carl Lee
                                          Carl Lee
                                          Ton Machielsen
                                          Ton Machielsen
                                          • Testroute segmenten
                                            Alderweireld Rudi 0
                                            Alderweireld Rudi 0
                                            105
                                            Hanza 0
                                            Hanza 0
                                          • Weather as a service
                                            Tegel Werner
                                            Tegel Werner
                                            Andy Smith 5
                                            Andy Smith 5
                                          • Lane view in Android Auto
                                            denWINNE
                                            denWINNE
