  4. Zooming in CarPlay & Android Auto
37 Posts 17 Posters 23.9k Views 8 Watching
  • Arno 0
    Arno 0
    Arno 0
    I've tried the new version a couple of times now in my car with CarPlay but it doesn't want to dynamically zoom in anymore. So it's stays on the same zoom level even if I'm driving slower or when entering a roundabout or exit. Very frustrating. Any ideas to solve this? Has maybe to do with my configuration but it has worked before. Thanks
    Arno
    silberfuchs67 a white mouse on the motorbike 2 Replies Last reply
    • Arno 0 Arno 0
      Arno
      silberfuchs67
      silberfuchs67
      silberfuchs67
      @Arno-0
      I tested the new version immediately after Release with CarPlay and had exactly the same issue / question. Hopefully it is not an issue sitting in front of the CarPlay device 🙂
      • Arno 0 Arno 0
        Arno
        @Arno-0 The solution to this is simple but at first I didn't know either: in the window where you have zoom and centring options, click again on the icon you used to open this zoom window. If you do this, MRA reverts to the Dynamic setting in which it automatically zooms again. If you wait until this window closes itself, MRA stays in "top camera" mode with fixed zoom and is thus not switched back!
        De oplossing hiervoor is simpel maar ik wist het eerst ook niet.
        In het venster waarin je zoom en centreer optie hebt nogmaals op het icoon klikken waarmee je dit zoom venster geopend hebt. Als je dit doet keert MRA terug naar de Dynamische instelling waarin hij weer automatisch zoomt.
        Als je wacht tot dat dit venster zichzelf sluit, dan blijft MRA in de modus "bovenaf camera" met vaste zoom en wordt dus niet terug geswitched!
        Léon Hassing GT JWR 2 Replies Last reply
        • Arno 0
          Arno 0
          Arno 0
          Dank voor je uitleg en ik ga het morgen even in de auto proberen.
          • silberfuchs67 silberfuchs67
            @Arno-0
            Adrian Avram
            Adrian Avram
            Adrian Avram
            @silberfuchs67 Android Auto is the same ... I prefer a downgrade than this this crap ....
            Best regards,
            Adrian
              Léon Hassing
              Léon Hassing
              Léon Hassing
              @white-mouse Ik heb dit uitgeprobeerd, maar ik zie toch geen automatische zoom, nadat ik teruggegaan ben naar de dynamische instelling.
                Vandaag weer gereden.
                Een automatische zoom is er niet in AA. Je ziet af en toe wel een beweging dat op automatische zoom lijkt maar het is zo beperkt dat het geen naam van zoom mag hebben.
                Omdat automatische zoom niet naar behoren werkt, heb ik door onduidelijkheid toch een paar keer een verkeerde afslag genomen.
                Toevallig gisteren weer eens met HereWeGo gereden. Deze heeft wel netjes een werkende automatisch zoom in AA.
                Komt er een afslag in beeld. Dan wordt er netjes steeds verder op die afslag ingezoomd. Na het nemen van de afslag wordt er weer uitgezoomd.
                Nu vind ik de standaard zoom niveau van HereWeGo veel te ver uitgezoomd maar dat is een andere discussie.
                • Fridjof
                  Fridjof
                  Fridjof
                  @Corjan-Meijerink , selecting waypoint of AA screen not working, phone OK
                  yesterday i did a nice ride in our area, prepared a route like a brezel, used the route as a track with all waypoints (~every 2 km) .
                  at an unwantedt shortcut with rerouting active the ride went craczy and at the end mra quits, after restarting the route with deactivated rerouting I schoud start from poit 1 instead of point 29 infront of me, I tried to shortcut to the point by pressing the point om the AA Screen, nothing changes only the map where paned, by doing the same on the phone it works a expected and the restart of the Track / route work well.
                  is this a known problem, can you reproduce it?,
                  best regards,
                  Fridjof
                    @Fridjof Well, you by design from Android Auto (and CarPlay) not select anything on the map by tapping 🙂
                    This is a user distraction while driving so not permitted.
                    Fridjof 1 Reply Last reply
                      GT JWR
                      GT JWR
                      GT JWR
                      @white-mouse unless I misunderstand what your saying (and I don't think I am), this did not work for me either. I can use the +/- to zoom in or out as desired, which then stayed on that zoom level unless adjusted again. A click on the icon that opened the zoom level did absolutely nothing.
                      I'm with all the others on this issue - if zoom (among other things) does not work properly on CarPlay, the Next App is unusable to me.
                      Seems every update takes 3 steps forward and 2 steps backward - a lot of past issues that were solved seem to come back - like zoom, wapypoint skipping, online vs offline, unable to calculate, etc. Seems like each update overwrites a previous fix. 😞 🤷
                        Fridjof
                        Fridjof
                        Fridjof
                        what is your solution to deal with this situation / problem?
                        regards
                        Léon Hassing 1 Reply Last reply
                        • Fridjof Fridjof
                          regards
                          Léon Hassing
                          Léon Hassing
                          Léon Hassing
                          @Fridjof Is your finding related to the subject of this thread: Zooming in Carplay/Android auto?
                          • Léon Hassing Léon Hassing
                            Fridjof
                            Fridjof
                            Fridjof
                            @Léon-Hassing
                            zooming is one of the needed on screen interactions on the dash AA or CP screen,
                            when MRA offers a feature to go dirct to a further point to shorten a route or skip some points on the phone screen while in a driving session with AA, I like to have this option also on the AA screen,
                            while driving I ca change the APP, skip or pause mp3 files, having a phone call, but no manual option to solve a scrambled route operating the AA Screen, why i can zoom and pan the map, but not selecting a given way or shaping point for reroutind the loaded route?
                            • Fridjof Fridjof
                              @Léon-Hassing
                              #34
                              @Fridjof, this basically comes down to Apple and Google limitations. They don't allow a lot of interaction in their apps. So the use of AA/CP comes with limitations. That is why many people prefer a native device.
                                Yes, AA/ACP has limitations.
                                For navigation apps, the biggest limitions i encounter are when you start a route or select a destination. These functionality is to limited in AA/ACP (in general).
                                But when the route is on your screen, then the limitations are not really limitations at all. Because when the navigation does it's job, then there is no need to touch the screen.
                                I am a fan of AA. Nice big built-in screen and a clean interface.
                                • David Rudgley
                                  David Rudgley
                                  David Rudgley
                                  I used MRA Navigation Next at the weekend through my AA Capuride W702 which was mostly a good experience. The only issue I have been getting is how the map is displayed on the Phone App is different on the AA device. The tilt and dynamic zoom doesn't look right whereby I don't get the same degree of 'look ahead' on AA compared to the phone screen. I have adjusted the Map Layer, Default Zoom correction and Tilt correction both at max (+2.0 and +15) which seemed to work for me. I have compared with TomTom Go and Google Maps and they don't suffer the same display difference between Phone and AA.
                                  MRA Gold Planner + App + Navigation Next user
                                  Android Pixel 9 Pro XL
                                  TomTomGo as backup
                                  KTM 1290 Super Adventure S
                                  Quad Lock + Phone + Carpuride W702
                                  2027 Kawasaki Z900 RS
                                  Beeline
                                  • David Rudgley David Rudgley
                                    Adrian Avram
                                    Adrian Avram
                                    Adrian Avram
                                    @David-Rudgley its also different between CarPlay and Android Auto. Car Play has more tilt and looks much better !
                                    Best regards,
                                    Adrian
                                    Adrian Avram
                                    Adrian Avram
                                    Bart De Medts
                                    Bart De Medts
                                    Léon Hassing
                                    Léon Hassing
                                    David Rudgley
                                    David Rudgley
                                    GT JWR
                                    GT JWR
                                    Edwin_M
                                    Edwin_M
                                    silberfuchs67
                                    silberfuchs67
                                    Fridjof
                                    Fridjof
                                    Arno 0
                                    Arno 0
                                    bluetuz
                                    bluetuz
                                    Gaetano 9
                                    Gaetano 9
                                      Garry Davis
                                      Garry Davis
                                    • MyRoute-app offline
                                      55.5k
                                    • Control screen font size
