  4. Recalculation of the route does not point to final destination.
23 Posts 7 Posters 9.5k Views 4 Watching
  • Axel Härtl Axel Härtl
    @ATLast Hi ATLast, in my opinion calimoto is far behind MRA. I had a calimoto subscription for some years and have canceled it. The options and, above all, the intensive further development based on user feedback at MRA are much better. So my advice - don't waste your time with calimoto - save it for your girlfriend. 😁
    Best, Axel 🙋‍♂️
    ATLast
    ATLast
    ATLast
    @Axel-Härtl
    Hi Axel.
    Thanks for your feedback.
    It confirms my opinion.
      @ATLast since we are talking about A to B routes, what limitations do other apps have that MRA does not have? I think Google Maps and Waze are much better for simple A to B routes and provide better notification and handling of detours, traffic etc.
      ATLast
      ATLast
      ATLast
      @RetiredWingMan
      The difference is in the options: in MRA, you can specify you want to avoid cities, populated areas, dirt roads: such options are not available in Maps or Waze (execpt dirt roads in Waze) and that makes a huge difference when you ask the program for a route.
      I suggest you try: set the desired options, and check the difference between Maps/Waze and MRA.
      Of course, setting part or all of these options and curvy roads won't give you the fastest route, but that's not the goal at that time.
      If I need to go straight to a place, I use Maps which monitors the traffic.
      • ATLast ATLast
        Hi.
        I use the app to ride through small routes and thus I choose a destination and let the program guide me.
        However, sometimes, I choose not the follow the computed route (road closed, better landscape, etc...) : I noticed that, when I choose not to follow the proposed route, MyRoute recalculates a new one but not to the destination: instead, it wants to send me where I left the planned route for the remaining part of the route.
        This is incorrect: in this screenshot taken about 750m from my destination and after riding about ten kilometers against the program's will, it wanted me to drive an additional 17 km.
        In this case, knowing the area, I could override the displayed route. But it is not the case when I don't know the region...
        The expected behaviour would be : recalculation to the final destination.
        PS: By the way, you will notice what seems to me a quality problem of the Here maps as buildings are wrongly displayed over the road. I tried selecting OSM map and the display was correct.
        #23
        @ATLast
        There is a solution:
        • Set a goal, like to choose a curve
        • Track is created in the app
        • Track save from V4.3.x possible
        • Open route lab in the app
        • Under Routes, search for the route track
        • Edit route track
        • Then "As route" spokes that generates WP on the route
        • Route corresponds to the track
          Choose route now in the Navi App
        • Start route
        • and go
        Recommendation:
        • WP automatically skips off
        • WP skips at the top right of the display, press longer, then you keep the power and decide for yourself.
        • WP for diversions simply press the next suitable longer and it fits again because until there is recalculated.
        VG
        Es gibt eine Lösung:
        • Ziel festlegen, gerne kurvenreich wählen
        • Track wird in der App erstellt
        • Track speichern ab V4.3.x möglich
        • Routenlabor in der App öffne
        • Unter Routen den Routen-Track suchen
        • Route-Track bearbeiten
        • Dann „Als Route“ Speichen das erzeugt WP auf der Route
        • Route entspricht dem Track
        Route jetzt in der Navi App wählen
        • Route starten
        • und los
        Empfelung:
        • WP automatisch überspringt Aus
        • WP überspringt am Display oben rechts länger drücken nutzen dann behält man die Macht und entscheidet selbst.
        • WP bei Umleitungen einfach den nächst passenden länger drücken und schon passt es wieder weil bis dort neu berechnet wird.
        VG
        Info comparison:
              1. (A to B) choose from left to right
                1.) = Route
                2.-4.) = Track
                You should know that 👋
        Info Abgleich:
              1. (A zu B) wähle von links nach rechts
                1.) = Route
                2.-4.) = Track
                Das sollte man wissen 👋
        Beispiel Track aus 4.) Aus Kurvenreich.
        Danach das Ergebnis
        GT JWR
        GT JWR
        Axel Härtl
        Axel Härtl
        ATLast
        ATLast
        Herko ter Horst
        Herko ter Horst
          David 38
          David 38
        • Download club route folders
        • Passwords
          Captain Haddock
          Captain Haddock
          Ed Lauwerens 0
          Ed Lauwerens 0
          410
          989
          13
          31
          475
