  4. Selecting routes!
Selecting routes!
2 Posts 2 Posters 669 Views 2 Watching
  • Craig Nelson
    Craig Nelson
    Craig Nelson
    I am trying to plan a trip for the first of September using the desktop application. It's picking certain routes I should take, but here is my question. Can I go from start to finish and pick the "specific" roads and highways I want to take instead of what it is suggesting? I've tried putting in stops or waypoints but it is still not giving me the option to take all of the specific routes I want to use. Is it possible at all to create and save the very specific routes I wanna use and save them so that I can send them to my Zumo XT?
    • nomko
      nomko
      nomko
      Banned
      @Craig-Nelson
      Ofcourse you can pick a route from the library and modify it according to your wishes.
      When adding a waypoint, you can drag and drop that waypoint to the road you want to drive on. And doing so, you must add or remove waypoints to change the route the way you like and avoid "strange and weird" reroutes.
      It's much easier to start a new route and then, after selecting your startpoint, select the roads to want to drive on by adding waypoints on those roads. This will give you much more freedom to create your own routes instead of what i suggested above, editing a route from the library.
      When creating your own route, you can add stop points for a break, lunch, nice views, etc.
      All routes created in MRA are saved automatically into your own personal library to be found under your profile.
      If you have the Garmin Zumo XT, you can use the Garmin Drive app on your mobile phone to transfer your routes onto youir XT or you can save the route to your computer, connect your XT to the computer and transfer the files directly onto your XT.
      nomko
      nomko
      Craig Nelson
      Craig Nelson
      • Move a GPS point on the map
      • Guida Libera
        Rolf Engelsman
        Rolf Engelsman
      • Trip summary view
