  4. Improved en route warnings
2 Posts 2 Posters 763 Views 2 Watching
  • Ramon Cutanda Lopez
    Ramon Cutanda Lopez
    Ramon Cutanda Lopez
    I find en route warnings such as speed cameras, traffic congestion or accidents very useful. However, their implementation leaves much to be desired.
    1. The speed cameras alert sound is so brief that most of the times I cannot hear it because of the lag of the Bluetooth system: by the time the Bluetooth system starts playing the sound it is already over. Maybe a repetition (two or three times) could fix the issue?
    2. The colour used for the icon of en route alerts is the same blue as the rest of the interface, so they don't stand out against other elements of the map. I would appreciate another colour for those icons, such as the one used for the petrol stations.
    3. I would appreciate a higher size of the icons to improve their visibility.
    4. Finally, regarding traffic congestions, I would also highlight the section of the route with stronger colours and width to improve its visibility.
    Thank you for taking this suggestions into consideration.
    Kind regards,
    • Ramon Cutanda Lopez Ramon Cutanda Lopez
      Kind regards,
      @Ramon-Cutanda-Lopez Thanks! 🙂
      1. Not an issue I hear often to be honest. I'd rather see the root cause / audio stability fixed than a repetition of alerts as workaround.
      2. The colour will be red if you are speeding, otherwise it's indeed blue. Other critical warning will be red by default.
      3. Agree, however we aren't able to scale those map icons yet
      4. Noted!
      Ramon Cutanda Lopez
      Ramon Cutanda Lopez
        Alderweireld Rudi 0
        Alderweireld Rudi 0
      • Map movement
