  4. Sharing route via email?
4 Posts 2 Posters 1.5k Views 1 Watching
  • LennyO
    I am in my route.
    It is on the map.
    It is Public.
    I click Share > Email and nothing happens....
    I would expect some kind of email program to open.
    Am I missing something in a setup?
    Thanks!
    • Avery Jones
      Avery Jones
      Avery Jones
      Check if you have an email client set up and as the default for handling email links. You might need to restart your device or reinstall the mapping app if the issue persists.
      LennyO 1 Reply Last reply
      • Avery Jones Avery Jones
        wrote on last edited by LennyO
        @Avery-Jones Is that a setting inside the MRA?
        Otherwise my email opens on links.
        Thanks!
        • Avery Jones
          Avery Jones
          Avery Jones
          The problem could be in your device's email setup, not inside the MyRoute app. Check that you have correctly set up your favorite email client. It is configured as the main application for managing email links. You can usually adjust this setting in your device settings, under "Default apps" on Android or within the "Mail" settings on iOS. If your email app is set as default already, but you still have trouble, try to reinstall My Route app will help with the problem.
          Avery Jones
          Avery Jones
          • Custom POI color and icons
          • F004 MRA Navigation Error
            12.2k
          • File / Creation date
            Robineke
            Robineke
            295
