  3. Gpx 1.0 or 1.1
Gpx 1.0 or 1.1
gpx versions
7 Posts 4 Posters 3.2k Views 2 Watching
  • Mark  McDonald
    Mark  McDonald
    Mark McDonald
    wrote on last edited by Mark McDonald
    What's the basic differences between saving a gpx file as 1.0 and 1.1?
    Many thanks, Mark
    • Mark  McDonald Mark McDonald
      Many thanks, Mark
      Cookie On Tour
      Cookie On Tour
      Cookie On Tour
      The difference between GPX1.0 and GPX 1.1
      GPX is the extension of a file for your navigation system. You can compare this abbreviation with the .docs extension of a Word file. The extension of a file can therefore tell you what type of file it is.
      GPX 1.1 can be seen as an 'updated' and 'improved' version of GPX1.0. A GPX 1.1 file can contain more information and therefore transfer to your navigation system. All new navigation systems can read a GPX 1.1 file. Older navigation systems cannot understand this 'more complicated' file type and therefore you still export a GPX1.0 file to older systems.
      Joerg
      (Cookie-On-Tour.de)
      Mark  McDonald 1 Reply Last reply
        Mark  McDonald
        Mark  McDonald
        Mark McDonald
        @Cookie-On-Tour
        For an old BMW Street Nav (Zumo 390) am I better to save as gpx 1.0 as opposed to 1.1 ?
        Cookie On Tour Mzokk 2 Replies Last reply
          @Cookie-On-Tour
          Cookie On Tour
          Cookie On Tour
          Cookie On Tour
          @Mark-McDonald if your nav can read the extended version 1.1 without any issues and you do not have any issues or miss any data I'd go with 1.1.
          Joerg
          (Cookie-On-Tour.de)
            @Cookie-On-Tour
            Mzokk
            Mzokk
            Mzokk
            @Mark-McDonald the Zumo 390 will work well with GPX 1.1 that's what I use with mine.
            • Mzokk Mzokk
              Mark  McDonald
              Mark  McDonald
              Mark McDonald
              @Mzokk Thanks 🙂
                The GPX 1.1 schema was released on August 9, 2004. GPX has been the de-facto XML standard for lightweight interchange of GPS data since the initial GPX 1.0 release in 2002. GPX is being used by hundreds of software programs and Web services for GPS data exchange, mapping, and geocaching.
                source: https://www.topografix.com/gpx.asp
                Just 2 years after the introduction of GPX 1.0 version 1.1 was already released. There has never been a new version ever since. It is safe to assume version 1.0 is obsolete if you use navigation software and hardware not older than 2005.
                Mzokk
                Mzokk
                Cookie On Tour
                Cookie On Tour
                Mark  McDonald
                Mark McDonald
                • Spoken notes are truncated
                • Navigating on NEX
                  524
                • V6 - Track Navigation
                  649
