  4. Zumo XT2 and Garmin Tread app
45 Posts 17 Posters 31.9k Views 5 Watching
  • austin 1
    austin 1
    austin 1
    I've recently added an XT2 to my stable and have run into an odd problem.
    Garmin documentation indicates the XT2 is no longer compatible with Garmin Basecamp. That in itself is not a surprise. What is a surprise is Garmin insists only output from the Garmin Tread application is compatible with the XT2.
    I've tried importing MRA gpx files in v1.1 and v1.2 format and neither work
    The only reliable workaround I've discovered is to delete any route files from MRA and convert the track files that are also sent along into routes. Somewhat cumbersome.
    Does anyone know if Garmin has adopted a more recent .gpx file format version or have they moved the route file format version into the 'private and not published' status?
    HABVEN aka MrMRA Lynchy67 Bill Funk Gerard Wullink 4 Replies Last reply
    • Reinhard-32
      Reinhard-32
      Reinhard-32
      Have a look at this thread:
      https://forum.myrouteapp.com/topic/6599/my-route-app-and-garmin-zumo-xt2?_=1717447484867
      Kindly regards
      Reinhard
      Montana 700i and Mac
      • austin 1 austin 1
        @austin-1
        Gpx 1.1 and 1.2 works great in the XT2
        Blake Sobiloff 1 Reply Last reply
          @austin-1
          Blake Sobiloff
          Blake Sobiloff
          Blake Sobiloff
          @Hans-van-de-Ven-MR-MRA said in Zumo XT2 and Garmin Tread app:
          @austin-1
          I'm not finding that to be the case. The only GPX version that my XT2 is accepting is 1.0; all the other versions cause the XT2 to choke when trying to recalculate the route for the selected vehicle profile (motorcycle). This is going to be very frustrating because all my shaping points will get called-out as waypoints.
          Note I'm transferring GPX files via the Garmin Tread app, as the built-in connector in MRA doesn't recognize my XT2 (even though Basecamp does).
          • Blake Sobiloff Blake Sobiloff
            @austin-1
            @Blake-Sobiloff
            That all the shaping points are called is because you use the gpx 1.0
              @Blake-Sobiloff
              Blake Sobiloff
              Blake Sobiloff
              Blake Sobiloff
              @Blake-Sobiloff
              Agree! I'd rather use GPX 1.1 or 1.2, but the routes exported from MRA aren't accepted by the XT2. Can't figure out why GPX 1.1 (or 1.2) are working for others, but not me.
                @Blake-Sobiloff
                @Blake-Sobiloff
                Please share the url of your route. Make sure it is set to publuc
                  @Blake-Sobiloff
                  Blake Sobiloff
                  Blake Sobiloff
                  Blake Sobiloff
                  @Blake-Sobiloff
                  https://www.myrouteapp.com/route/open/9352606
                  Thanks for taking a look!
                    @Blake-Sobiloff
                    Reinhard-32
                    Reinhard-32
                    Reinhard-32
                    @Blake-Sobiloff Some of the waypoints are not exactly placed. It is recommended to put all waypoints exactly on the road and not several meters or yards besides the roads. Otherwise the import can fail.
                    Kindly regards
                    Reinhard
                    • Reinhard-32 Reinhard-32
                      Blake Sobiloff
                      Blake Sobiloff
                      Blake Sobiloff
                      @Reinhard-32 said in Zumo XT2 and Garmin Tread app:
                      @Blake-Sobiloff Some of the waypoints are not exactly placed. It is recommended to put all waypoints exactly on the toad an not several meters or yards besides the roads. Otherwise the import can fail.
                      Sure enough, that seemed to be the problem—I had the waypoints for my stops on the actual gas station or restaurant, not on the road closest to them. Now I've been able to import ".gpx 1.1 (route, track, POI)" and the XT2 will succeed in recalculating the route! Yea!
                      However, it's still treating my shaping points as waypoints. 😢 I can manually change those on the XT2, but I'm going to play around with some of the other export options and see if they'll let me avoid that manual effort.
                      Thanks!
                        Thanks!
                        Blake Sobiloff
                        Blake Sobiloff
                        Blake Sobiloff
                        @Blake-Sobiloff said in Zumo XT2 and Garmin Tread app:
                        Hmm, I deleted and re-imported a few times and it eventually recognized the shaping points as shaping points. Flakey Garmin… 🙄
                        • Carl Lee
                          Carl Lee
                          Carl Lee
                          wrote on last edited by Carl Lee
                          Brand new XT2, spent the afternoon dewiring and rewiring the bike, splicing a fuse in etc etc. Only the fact I did all that meant that the unit didn't get sent back. I'm fairly nav savvy but how frustrating!
                          Anyway, here is my (hopeful) solution to getting a MRA route into the XT2:
                          Build the route using HERE, motorcycle mode, expand the number of shaping points to approx 25/100miles. Hit the MRA down arrow but only to download in GPX 1.1. I’ve tried the others with no luck, the unit or Explore doesn’t seem to like 1.2. Then open Tread and import your gpx. Then edit the route, let it calculate and rename it (just add a 1 or whatever). Click the close X and save.
                          This seems to work for me.
                          Now, anyone tell me how I also make the track visible without all the palaver of stopping Explore?
                          • austin 1 austin 1
                            Lynchy67
                            Lynchy67
                            Lynchy67
                            #13
                            @austin-1 said in Zumo XT2 and Garmin Tread app:
                            This is absolute nonsense.
                            You can use 1.1 and 1.2 using Garmin Express without ever having to use the awfull Tread App.
                            truckpilot 1 Reply Last reply
                            • Lynchy67 Lynchy67
                              truckpilot
                              truckpilot
                              truckpilot
                              @Lynchy67 i think you mean Garmin explore instead of garmin express
                              HABVEN aka MrMRA Lynchy67 2 Replies Last reply
                              • truckpilot truckpilot
                                @truckpilot
                                With a windows PC you can use the connector
                                With a Mac, save the route as (gpx 1.1 or gpx 1.2) and with Android File Transfer, transfer the route tot youte XT2 to the gpx folder.
                                When using the MRA App and the Tread App use the gpx 1.1 file, because Garmin Explore makes a mess of the gpx 1.2 file.
                                Carl Lee 1 Reply Last reply
                                  Lynchy67
                                  Lynchy67
                                  Lynchy67
                                  @truckpilot
                                  No, I really do mean Garmin Express.
                                  It allows you to easily upload your gpx files diretly into the GPX Folder on the XT2
                                  truckpilot Sam Ellis 2 Replies Last reply
                                  • Carl Lee
                                    Carl Lee
                                    Carl Lee
                                    #17
                                    Been playing a little more with this thing. I'm now happy that my system works fine to wirelessly import MRA routes and tracks in GPX 1.1 (auto recalculate in auto). Important for when on bike tours away from a computer.
                                    Using the MRA wired connector also means you can import GPX 1.2 files in the normal way which is great as these follow your track exactly (auto recalculate off).
                                    I've also found how to make a track visible under the route. On the main map, click on Layers - Collections - Unorganised. Make sure first to make the intended track your colour of choice (black seems to work best), make it widest and 'show on top'. Your other tracks may be there but they will probably be yellow. Obviously, reorganise or delete after use to avoid confusion.
                                    I hope I'm not teaching anyone to suck eggs and this is useful. At least it's a starting point to develop further discussion.
                                    Maybe a new GPX will get created to work with Garmin Explore.
                                    Ron Z 1 Reply Last reply
                                      @truckpilot
                                      Carl Lee
                                      Carl Lee
                                      Carl Lee
                                      @Hans-van-de-Ven-MR-MRA thanks, good info and I'm getting to grips with it now.
                                      • Lynchy67 Lynchy67
                                        @truckpilot
                                        truckpilot
                                        truckpilot
                                        truckpilot
                                        @Lynchy67
                                        Ok. Can you explain please how to do this?
                                        At this moment i can’t find any button or something else to import .gpx file to the unit.
                                        Lynchy67 1 Reply Last reply
                                          @Lynchy67
                                          Lynchy67
                                          Lynchy67
                                          Lynchy67
                                          #20
                                          @truckpilot
                                          In Google type Garmin Express Download.
                                          Start Garmin Express.
                                          Then Plug the XT/XT2 into your Laptop.
                                          It will take a few minutes for the XT/XT2 to Sync.
                                          You will hear a beep when the XT/XT2 is synced.
                                          Go to the GPX Folder.
                                          Paste your GPX Files into the GPX Folder.
                                          Disconnect the XT/XT2 and power it up. It will ask you to select the files you wish to import.
                                          Job Done.
                                          If you are on a Mac I can't help with that.
                                          Bouke Ent truckpilot 2 Replies Last reply
                                          Bouke Ent
                                          Bouke Ent
                                          Carl Lee
                                          Carl Lee
                                          TomOnTour
                                          TomOnTour
                                          Reinhard-32
                                          Reinhard-32
                                          Gerard Wullink
                                          Gerard Wullink
                                          Sam Ellis
                                          Sam Ellis
                                          Ron Z
                                          Ron Z
                                          Andy Beviere
                                          Andy Beviere
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Lynchy67
                                          Lynchy67
                                          truckpilot
                                          truckpilot
                                          Bill Funk
                                          Bill Funk
                                          Blake Sobiloff
                                          Blake Sobiloff
                                          austin 1
                                          austin 1
                                            42
                                          • screen
                                          • Live tracking
                                            203
                                          • Rondrit generator ervaring
                                            AWDC LAO
                                            AWDC LAO
                                            Sam Kramer
                                            Sam Kramer
