  4. Zumo XT2 and Garmin Tread app
45 Posts 17 Posters 32.8k Views 5 Watching
  • Reinhard-32 Reinhard-32
    @Blake-Sobiloff Some of the waypoints are not exactly placed. It is recommended to put all waypoints exactly on the road and not several meters or yards besides the roads. Otherwise the import can fail.
    Blake Sobiloff
    Blake Sobiloff
    Blake Sobiloff
    @Reinhard-32 said in Zumo XT2 and Garmin Tread app:
    @Blake-Sobiloff Some of the waypoints are not exactly placed. It is recommended to put all waypoints exactly on the toad an not several meters or yards besides the roads. Otherwise the import can fail.
    Sure enough, that seemed to be the problem—I had the waypoints for my stops on the actual gas station or restaurant, not on the road closest to them. Now I've been able to import ".gpx 1.1 (route, track, POI)" and the XT2 will succeed in recalculating the route! Yea!
    However, it's still treating my shaping points as waypoints. 😢 I can manually change those on the XT2, but I'm going to play around with some of the other export options and see if they'll let me avoid that manual effort.
    Thanks!
    Blake Sobiloff 1 Reply Last reply
    • Blake Sobiloff Blake Sobiloff
      Thanks!
      Blake Sobiloff
      Blake Sobiloff
      Blake Sobiloff
      @Blake-Sobiloff said in Zumo XT2 and Garmin Tread app:
      Hmm, I deleted and re-imported a few times and it eventually recognized the shaping points as shaping points. Flakey Garmin… 🙄
      • Carl Lee
        Carl Lee
        Carl Lee
        Brand new XT2, spent the afternoon dewiring and rewiring the bike, splicing a fuse in etc etc. Only the fact I did all that meant that the unit didn't get sent back. I'm fairly nav savvy but how frustrating!
        Anyway, here is my (hopeful) solution to getting a MRA route into the XT2:
        Build the route using HERE, motorcycle mode, expand the number of shaping points to approx 25/100miles. Hit the MRA down arrow but only to download in GPX 1.1. I’ve tried the others with no luck, the unit or Explore doesn’t seem to like 1.2. Then open Tread and import your gpx. Then edit the route, let it calculate and rename it (just add a 1 or whatever). Click the close X and save.
        This seems to work for me.
        Now, anyone tell me how I also make the track visible without all the palaver of stopping Explore?
        • austin 1 austin 1
          I've recently added an XT2 to my stable and have run into an odd problem.
          Garmin documentation indicates the XT2 is no longer compatible with Garmin Basecamp. That in itself is not a surprise. What is a surprise is Garmin insists only output from the Garmin Tread application is compatible with the XT2.
          I've tried importing MRA gpx files in v1.1 and v1.2 format and neither work
          The only reliable workaround I've discovered is to delete any route files from MRA and convert the track files that are also sent along into routes. Somewhat cumbersome.
          Does anyone know if Garmin has adopted a more recent .gpx file format version or have they moved the route file format version into the 'private and not published' status?
          Lynchy67
          Lynchy67
          Lynchy67
          @austin-1 said in Zumo XT2 and Garmin Tread app:
          This is absolute nonsense.
          You can use 1.1 and 1.2 using Garmin Express without ever having to use the awfull Tread App.
          truckpilot 1 Reply Last reply
          • Lynchy67 Lynchy67
            truckpilot
            truckpilot
            truckpilot
            @Lynchy67 i think you mean Garmin explore instead of garmin express
            HABVEN aka MrMRA Lynchy67 2 Replies Last reply
            • truckpilot truckpilot
              @truckpilot
              With a windows PC you can use the connector
              With a Mac, save the route as (gpx 1.1 or gpx 1.2) and with Android File Transfer, transfer the route tot youte XT2 to the gpx folder.
              When using the MRA App and the Tread App use the gpx 1.1 file, because Garmin Explore makes a mess of the gpx 1.2 file.
              Carl Lee 1 Reply Last reply
                Lynchy67
                Lynchy67
                Lynchy67
                @truckpilot
                No, I really do mean Garmin Express.
                It allows you to easily upload your gpx files diretly into the GPX Folder on the XT2
                truckpilot Sam Ellis 2 Replies Last reply
                • Carl Lee
                  Carl Lee
                  Carl Lee
                  #17
                  Been playing a little more with this thing. I'm now happy that my system works fine to wirelessly import MRA routes and tracks in GPX 1.1 (auto recalculate in auto). Important for when on bike tours away from a computer.
                  Using the MRA wired connector also means you can import GPX 1.2 files in the normal way which is great as these follow your track exactly (auto recalculate off).
                  I've also found how to make a track visible under the route. On the main map, click on Layers - Collections - Unorganised. Make sure first to make the intended track your colour of choice (black seems to work best), make it widest and 'show on top'. Your other tracks may be there but they will probably be yellow. Obviously, reorganise or delete after use to avoid confusion.
                  I hope I'm not teaching anyone to suck eggs and this is useful. At least it's a starting point to develop further discussion.
                  Maybe a new GPX will get created to work with Garmin Explore.
                  Ron Z 1 Reply Last reply
                    @truckpilot
                    Carl Lee
                    Carl Lee
                    Carl Lee
                    @Hans-van-de-Ven-MR-MRA thanks, good info and I'm getting to grips with it now.
                    • Lynchy67 Lynchy67
                      @truckpilot
                      truckpilot
                      truckpilot
                      truckpilot
                      @Lynchy67
                      Ok. Can you explain please how to do this?
                      At this moment i can’t find any button or something else to import .gpx file to the unit.
                      Lynchy67 1 Reply Last reply
                        @Lynchy67
                        Lynchy67
                        Lynchy67
                        Lynchy67
                        #20
                        @truckpilot
                        In Google type Garmin Express Download.
                        Start Garmin Express.
                        Then Plug the XT/XT2 into your Laptop.
                        It will take a few minutes for the XT/XT2 to Sync.
                        You will hear a beep when the XT/XT2 is synced.
                        Go to the GPX Folder.
                        Paste your GPX Files into the GPX Folder.
                        Disconnect the XT/XT2 and power it up. It will ask you to select the files you wish to import.
                        Job Done.
                        If you are on a Mac I can't help with that.
                        Bouke Ent truckpilot 2 Replies Last reply
                        • Lynchy67 Lynchy67
                          @truckpilot
                          Job Done.
                          @Lynchy67 strange because i do not need garmin express to connect my xt to windows pc. i only have to use it to update mijn garmin's.
                          i just connect xt wired to pc and i can copy gpx.
                          • TomOnTour
                            TomOnTour
                            TomOnTour
                            @Bouke-Ent
                            This is different for the XT2, as they changed the file system format or the communication protocols. I am nit sure which is the one that have changed (at least for the Mac) users. I could connect my XT to my Mac and go to the GPX folder, but with the XT2 you need a special peace of software (Android file transfer) to get it "connected" with the Macs. Not sure if there is something similar in the windows world.
                            MyRoute-APP Navigation Next (V6.0.0 - 489) on DMD T781
                            MRA Navigation Next (Lifetime Gold)
                            MRA Routeplanner NEXT beta (Lifetime early access)
                            truckpilot Bouke Ent 2 Replies Last reply
                            • TomOnTour TomOnTour
                              @Bouke-Ent
                              truckpilot
                              truckpilot
                              truckpilot
                              @TomOnTour
                              On windows pc normally no other program needed.
                              When i connect my XT2,it shows up in the file manager/explorer ( verkenner in dutch).
                              • Lynchy67 Lynchy67
                                @truckpilot
                                Job Done.
                                truckpilot
                                truckpilot
                                truckpilot
                                @Lynchy67 like @Bouke-Ent mentioned, you don’t need garmin express to vieuw your XT2 in your Windows file manager/ explorer. Garmin express only for updating device's firmware,maps etc via usb connection.
                                  Lynchy67
                                  Lynchy67
                                  Lynchy67
                                  @truckpilot @Bouke-Ent
                                  I actually prefer to use Garmin Express for my XT2
                                  @truckpilot said in Zumo XT2 and Garmin Tread app:
                                  Garmin Express only for updating device's firmware,maps etc via usb connection.
                                  That is simply not true!
                                  If you look at my screen shots you can see I have direct access to the GPX folder and I can upload multiple GPX Files.
                                  I'll stick with my method.
                                  • Lynchy67 Lynchy67
                                    truckpilot
                                    truckpilot
                                    truckpilot
                                    @Lynchy67 you don’t have to open garmin express to see the XT2 in the file manager.
                                    It’s your windows system that normally ( depending settings) detect a ( new) device and opens it in your file manager/ Windows explorer. Try it once without opening garmin explorer.
                                    I’m been doing this also to import things directly in the gps(xt2) , internal memory and sd card.
                                      @Bouke-Ent
                                      @TomOnTour thanks for explaning. do you know if otg then still works. my xt i can connect with otg cable to my samsung active 2.
                                      TomOnTour 1 Reply Last reply
                                      • Bouke Ent Bouke Ent
                                        TomOnTour
                                        TomOnTour
                                        TomOnTour
                                        @Bouke-Ent
                                        I might be stupid, but I don't know what "OTG" means. Sorry, for asking 🙂
                                        Bouke Ent MotoCon 2 Replies Last reply
                                          @Bouke-Ent
                                          @TomOnTour you are not stupid... with otg cable you van connect a tablet or phone to a usb device like a usb stick or a navigation device. there are lightning and usb variants. with this you can connect your garmin to a phone or tablet without any pc. i use it when i do not have good internet (wifi or 4g) and i want to transfer a gpx file to my garmins or tomtom. only important thing is that your garmin is in USB storage mode. in the past i had to correct this on my 345. my xt was setup correctly.
                                          Andy Beviere
                                          Andy Beviere
                                          TomOnTour
                                          TomOnTour
                                          Carl Lee
                                          Carl Lee
                                          Gerard Wullink
                                          Gerard Wullink
                                          Sam Ellis
                                          Sam Ellis
                                          Ron Z
                                          Ron Z
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Lynchy67
                                          Lynchy67
                                          truckpilot
                                          truckpilot
                                          Bill Funk
                                          Bill Funk
                                          Blake Sobiloff
                                          Blake Sobiloff
                                          austin 1
                                          austin 1
                                          • Online map settings
                                            MartinW
                                            MartinW
                                          • Real-time traffic
                                            Òscar
                                            Òscar
                                            Andy Nicholson
                                            Andy Nicholson
                                          • HERE map not calibrated
                                            MartinW
                                            MartinW
                                          • Myrouteappstay
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Navigatie met DMD tablet
                                          • Show on the maps's button
