  2. Camper Discussion
  3. Motorhome subscription, what do I need?
Scheduled Pinned Locked Moved Camper Discussion
6 Posts 3 Posters 3.1k Views 1 Watching
  • Duncan Mills
    Duncan Mills
    Duncan Mills
    I have just purchased the Gold subscription. I had hoped that this would cover my motorhome, apparently it does not. What else do I need to buy?
    Con Hennekens Nick Carthew 2 Replies Last reply
    • Duncan Mills Duncan Mills
      @Duncan-Mills, Gold is a route planner subscription. If you want to be able to use the app for navigating, you need a Navigation Next subscription.
        @Duncan-Mills The default transport mode can be set in your account page or you can change individual routes in the Route-information tab.
        If you want to navigate using MyRoute-app then you will need a navigation subscription.
        Duncan Mills 1 Reply Last reply
          Duncan Mills
          Duncan Mills
          Duncan Mills
          @Nick-Carthew . So I need both?
            @Con-Hennekens Ninja fingers beat me to it again 😂
              @Duncan-Mills Not strictly true, you will have access to the HERE planning map (used by MRA Navigation Next) with just a navigation subscription. But if you want access to all of the planning tools and additional maps, then a Gold route planner subscription is also recommended.
              Duncan Mills
              Duncan Mills
                Kevin Bird
                Kevin Bird
              • Statement on map spinning
                17
                36
                3.5k
              • First time version 6 and AA
              • Some minor improvements ;-)
