  4. Wrong 'direction arrow'
3 Posts 2 Posters 990 Views 1 Watching
  • Martin Hofman
    Martin Hofman
    Martin Hofman
    Does anyone ever have/had the same problem? Arrow says Left while it should be Right.....
    200 meters closer it shows the right 'Right'
    • richtea999
      @Martin-Hofman Quote possibly it is the HERE bug related to using 'Motorbike' as the vehicle mode.
      Swap the travel mode to 'Car' and see if you still have the same problem. See here:
      https://forum.myrouteapp.com/topic/6904/roundabout-issue-solved?_=1716931700284
      Just beware that although it says the bug is fixed that is not yet totally confirmed AFIAK.
      Martin Hofman 1 Reply Last reply
      • richtea999 richtea999
        Martin Hofman
        Martin Hofman
        Martin Hofman
        @richtea999 Thanks! But 'unfortunatelly' it was already on car-modus...
        Nevertheless, I will keep an extra eye open for this setting it it occurs again.
        Martin Hofman
        Martin Hofman
          superg
          superg
          Garry Davis
          Garry Davis
        • 6.0.0 - 515 graphics appear much clearer.
