  4. BMW Connected Ride Navigator not importing waypoints
41 Posts 7 Posters 23.9k Views 4 Watching
  • paul69 paul69
    @Dikke-Wim said in BMW Connected Ride Navigator not importing waypoints:
    Sometimes I'm hard learning...
    hi
    did you look at the thread I inserted. although it's a different forum.
    I have actually copied into pdf doc and have easy access to it, for when i forget how to do it.
    Dikke Wim Offline
    Dikke Wim Offline
    Dikke Wim
    @paul69
    Could you upload the pdf file here?
    That would be nice.
    paul69 1 Reply Last reply
    • Hans van de Ven MR.MRA Hans van de Ven MR.MRA
      @Topcat502
      Use the TomTom map, use max 50 shaping points. Then send it to the connected app, choose the track and route with 50 points.
      Then in the route file tick on the 3 dots in the upper right corner and choose convert to route with points. The 50 points will be visible.
      Choose that route on the CRN and you can also make the track visible on the CRN
      Dikke Wim Offline
      Dikke Wim Offline
      Dikke Wim
      @Hans-van-de-Ven-MR-MRA
      Hans, I'm curious. Why would you use the route with the waypoints visible? There is no difference between VIA-points and FORM-points. For me it would make sense if you could maken only the VIA-point visible (lunch stops, coffee breaks, castles, etc.). When do you use these waypoints that are visible in the CRN as balloons?
      Maybe I miss it but wat is the advantage of seeing all waypoints? The route without the waypoints is the same.
      The only thing I can think of is that you can REMEMBER that e.g. waypoint 20 is a coffee break.
      A workaround is to add favourites by hand (one by one) in the CRN. These points are visible as a balloon with an asterisk.
      Hope te hear from you!
      Hans van de Ven MR.MRA 1 Reply Last reply
      • Dikke Wim Dikke Wim
        @paul69
        That would be nice.
        paul69 Offline
        paul69 Offline
        paul69
        @Dikke-Wim
        hi,
        not sure it's possible to upload files
        K1600 GTL
        Oukitel RT3
        iPhone 13 Pro, carpuride 702b
        Dikke Wim 1 Reply Last reply
        • paul69 paul69
          @Dikke-Wim
          hi,
          Dikke Wim Offline
          Dikke Wim Offline
          Dikke Wim
          @paul69
          I don't see an option either. No problem. I think I have enough information already.
            Hans van de Ven MR.MRA Do not disturb
            @Dikke-Wim
            The CRN sees all points as injured points, if you change the name of the points, you will see the name in the CRN at a point, for example Coffee or lunch.
            You will not receive a notification from the CRN, but you can see them. Or indeed remember the number where you want to stop.
              @paul69
              paul69 Offline
              paul69 Offline
              paul69
              hi @Dikke-Wim
              when i found the thread regarding this process (at the beginning of this thread), i just copied the whole explanation into a word doc, then formatted it to make it more readable and then exported to pdf. i am no computer wizard.
              incidentally @Topcat502 who started this topic, i hope all these replies have helped you with your query.
              K1600 GTL
              Oukitel RT3
              • Topcat502 Offline
                Topcat502 Offline
                Topcat502
                wrote on last edited by Topcat502
                #27
                Hi all. Really appreciate the help from all, but what an absolute faff!! It looks like MRA and CRN doesn't play well together and hopefully MRA will rectify this in the future. Other GPX files we have downloaded from other bike sites have worked fine. We ride to planned routes so need the waypoints/shaping points, always have. Sadly, regretting buying MRA/CRN at present. Fingers crossed on future updates.
                • Topcat502 Topcat502
                  @Topcat502
                  So what doesn't work? Can you share some screenshots of what you see in the CRN of other gpx files and not of an MRA file.
                  Topcat502 1 Reply Last reply
                    @Dikke-Wim
                    Dikke Wim Offline
                    Dikke Wim Offline
                    Dikke Wim
                    Ik probeer de namen van de punten in de Connect Ride App te veranderen nadat ik een route vanuit MRA heb geëxporteerd als GPX 1.1 file en heb omgezet naar route met waypoints.
                    Helaas kan ik dan geen namen van de routepunten aanpassen.
                    Hooguit kan in in MRA de namen veranderen (bv. Lunch, koffie, etc.), maar die namen komen niet terug in de Connect Ride app op mijn iPhone. Ook niet op de CRN zelf.
                    Hoe kun jij de namen veranderen zodat ze uiteindelijk op de CRN zichtbaar worden?
                    Ik hoor graag van je Hans!
                      @Topcat502
                      Topcat502 Offline
                      Topcat502 Offline
                      Topcat502
                      @Hans-van-de-Ven-MR-MRA !
                      I'm not saying it doesn't work, but it just seems very strange to need these workarounds when previously technology has worked fine.
                      The top route is a gpx file showing a route made in Basecamp. As you can see it has the waypoints already set up as per the gpx file created. This can be imported directly into the CRN.
                      This shows the same route created in MRA and exported as GPX 1.1
                      As you can see the CRA shows them as support points and as you have explained, the route has to be converted to waypoints in the app, you then have to export this to the CRN (because you don't have the option to convert in the CRN. )
                      Other points to note are that, unlike our previous NAV5, there isn't the option to "fix" your route. Therefore, if you're like us and ride to planned routes (either from mags or ones we've created) we have to add more waypoints than previously added because it doesn't recognise shaping points and is more likely to take you off your route. We have to add them in after junctions so that it sticks to the route as much as possible, but then if needed we can skip them due to traffic/road closure etc. Therefore, the 50 max waypoints doesn't help and we have to break up our tours into smaller chunks. I understand this isn't an MRA issue and hopefully the CRN will provide further updates from everyone's feedback as it's still relatively new.
                      As I say it's not impossible, but for us, using Basecamp and the NAV5 was straight forward to plan, export and ride our routes compared to MRA/CRA/CRN set up.
                        @Topcat502
                        Different technology.
                        BMW Nav 5 and Basecamp = Garmin
                        BMW Connected App and the CRN = TomTom
                        Jez 0 1 Reply Last reply
                        • Topcat502 Offline
                          Topcat502 Offline
                          Topcat502
                          A further update to this
                          We've now done a ride where we have converted to waypoints through the Connected Ride App and then used the CRN to navigate. It doesn't recognise the difference between a destination and a waypoint, as the navigation display shows ETA for the next waypoint and the destination as the same. It also removes the waypoint from the route on the map as you go along. It doesn't alert you to the name of the waypoint either, it just tells you (sometimes) that you have reached your destination.
                            @Topcat502
                            Jez 0 Offline
                            Jez 0 Offline
                            Jez 0
                            Hi just started withn this ConnectedRide Navigator.
                            Question 1) Do i have to use TOMTOM Maps as default to export the GPX 1.1 file so it's recognised accurately in Navigator or does it not matter?
                            I have created both the track and Route files to test with HERE Maps and the TOMTOM Maps- not sure what is going to work here.
                            Question 2) Should i just create the Routes with the maximum 50 Shaping points and use that in GPX 1.1 format? either TOMTOM or HERE Maps (what works)?
                            Question 3) I preume if a track is too large it just can't handle it. Had a error when testing.
                            Hope they update so we can see the detail of way points, as that's most dissapointing.
                            Regards
                            Jez
                            • Jez 0 Jez 0
                              Regards
                              Jez
                              @Jez-0
                              Hello
                              1. Yes, it is best to use the TomTom card, because the CRN also uses the TomTom card. And the GPX 1.1 file also gives the best result and you can make the Shaping points visible in the connected app and therefore also on the CRN. There are no formation points in a GPX 1.2.
                              2. You can create more than 50 Shaping points, only the connected app can make a maximum of 50 visible.
                              3. If you have more than 50 Shaping points in your route, take the track, this is the file with more than 3000 support points.
                                @Jez-0
                                Hello
                                Jez 0 Offline
                                Jez 0 Offline
                                Jez 0
                                Many thanks i will try that.
                                Do you think we will eventually be able to obtain the information as per way points in MRA Navigation. Or at least some way to communicate the notes for each way point like Fuel - Coffee stop etc.
                                Regards
                                Jez
                                • Jez 0 Jez 0
                                  Regards
                                  Jez
                                  @Jez-0
                                  No, I don't think so, because TomTom has to change this
                                    @Jez-0
                                    Jez 0 Offline
                                    Jez 0 Offline
                                    Jez 0
                                    Hi,
                                    On another note when we look at routes could you add a field so we can see what mapping we used to create; either TOMTOM or HERE Maps.
                                    Save me having to open all the routes.
                                    • Jez 0 Jez 0
                                      Hi,
                                      @Jez-0
                                      When you create a route you can choose the map
                                        @Jez-0
                                        Jez 0 Offline
                                        Jez 0 Offline
                                        Jez 0
                                        Hi,
                                        Yes i know that - but if i am planning for TOMTOM or HERE Maps it be good to see what system i used in the information. Maybe we could add other details like avoidances used and if road closures are ignored etc.
                                        Only other way but without all that detail would be to create seperate folders fot HERE and TOMTOM but missing the information in that box that would be nice.
                                        Regards
                                        Jez
                                          @Topcat502
                                          Kenneth de Miranda Offline
                                          Kenneth de Miranda
                                          @Hans-van-de-Ven-MR-MRA yes correct. I just uploaded a topic on the same issue, did not know you had already posted this here. Is the 50 points a Tom Tom limit or is it just the Connected Ride app the limiting factor?
                                          paul69
                                          paul69
                                          Dikke Wim
                                          Dikke Wim
                                          Jez 0
                                          Jez 0
                                          Kenneth de Miranda
                                          Kenneth de Miranda
                                          Philip Goh
                                          Philip Goh
                                          Topcat502
                                          Topcat502
                                          • App probleem scenic route niet mogelijk
                                            ErikMatthezing
                                            ErikMatthezing
                                            326
                                          • The most important rule: all content is to be posted in English 🇬🇧 unless the post is made in the language specific area in the Self Support forum.
                                          • routes opening as tracks on iphone
                                          • Android auto loopt vast op Aoocci scherm
                                            paul69
                                            paul69
                                          • Rondrit maken lukt niet
                                            Rob Vonk
                                            Rob Vonk
                                            295
                                          • One time glitch after lost gps signal
                                          • Is there a site to go to for getting custom POI symbols
                                          • Traffic Aware setting toggle greyed out
                                            Peter Burch 1 0
                                            Peter Burch 1 0
                                            788
