  3. Importing POI into Favoutites
8 Posts 4 Posters 2.0k Views 3 Watching
  • Peter Croft
    Peter Croft
    Peter Croft
    Good day all. New to this program. I have been used to having a bank of waypoints or POI that I can copy between routes etc. Have GPX files from another program. Have imported the routes - fine. Trying to find where the waypoint are and if I can import them into some sort of library for me to use later?
    Thanks
    • Peter Croft Peter Croft
      Thanks
      @Peter-Croft
      Import the poi file as poi. Then open a route, go to points of interest, left menu, then hit the library tab.
      Peter Croft 1 Reply Last reply
        @Peter-Croft
        Peter Croft
        Peter Croft
        Peter Croft
        @Hans-van-de-Ven-MR-MRA Thank you. Does the same apply with waypoints? I use Basecamp at present.
          @Peter-Croft sort of. My solution was: export every single folder in Basecamp as an GPX file and import it under the POI section in MRA. In that way you keep your order you had in Basecamp. Like this 167eaf42-db12-4151-ac84-4680da27377c-image.png
          MRA Lifetime Gold
          No6671 1 Reply Last reply
          • Peter Croft
            Peter Croft
            Peter Croft
            Thank you everyone. I shall play.
            • Travellexxie Travellexxie
              No6671
              No6671
              No6671
              @Lex-Kloet-RX
              Hi. 🙂
              Could you send me your POIs of Ducati-Europe?
              Goran
              Get up. Travel. Make friends. Sleep. Repeat.
              • No6671 No6671
                @Lex-Kloet-RX
                Hi. 🙂
                @No6671 yeah, but I have to warn you, it is a very old file. On Ducati's site, you find the actual dealers faster and it is more trustworthy 😉
                Link to Ducati stores(old)
                MRA Lifetime Gold
                  No6671
                  No6671
                  No6671
                  @Lex-Kloet-RX
                  Thank you anyway. 🙂
                  I just have a break and will check out the KTM SA-R, the -S version and the new GS1300. So maybe I will need some other POIs hahaha.
                  Goran
                  No6671
                  No6671
                  Peter Croft
                  Peter Croft
                    Alderweireld Rudi 0
                    Alderweireld Rudi 0
                    100
                    Hanza 0
                    Hanza 0
                  • 1 bij app icoontje
                  • Map Layers
                    Don Stauffer
                    Don Stauffer
                    Andy Smith 5
                    Andy Smith 5
                  • Weather as a service
                  • Units of Measurement
                    Mzokk
                    Mzokk
