  2. Routes & Tracks
  3. How to make POI set
How to make POI set
10 Posts 6 Posters 3.7k Views 1 Watching
  • Hanza 0
    Hanza 0
    Hanza 0
    Hi, I want to make a poi set of all our club members.
    Does anyone know how to make that?
    RideOnWithFriends Nick Carthew Travellexxie 3 Replies Last reply
    • Hanza 0 Hanza 0
      RideOnWithFriends
      RideOnWithFriends
      RideOnWithFriends
      @Hanza-0 you have to distribute by gps file
      Best Regards - cu on my channel
      https://www.youtube.com/@rideonwithfriends
      Juergen
      • Hanza 0 Hanza 0
        @Hanza-0 Position a route point at each location that you want a POI. Name the route point with the name that you would like to see in the POI. The route planner will plan a route, you’re not interested in the route, just the positions of each route point, but at this point you could name the route with the name that you would like your list of POIs to be called. When they are all in place, Choose Save as and save it as a .CSV file to your PC. You can share this file for friends to add to their MRA POI Library and you can add it to your MRA POI Library like this:
        To add it to your library, go to Route lab and click Upload, choose the POI tab. Click the green Choose files button and add the .CSV file then click Import.
        You will now see your POIs in Library tab of your MRA POI library.
        • Peter Bijnsdorp
          Peter Bijnsdorp
          Peter Bijnsdorp
          If I follow this procedure I get an empty Excel file. Should I start by creating a new route, place the points in it, rename them and then save the route as and then choose Poi file? to then distribute it and then import it into MRA?
          • Peter Bijnsdorp Peter Bijnsdorp
            @Peter-Bijnsdorp Yes
            Peter Bijnsdorp 1 Reply Last reply
              Peter Bijnsdorp
              Peter Bijnsdorp
              Peter Bijnsdorp
              @Nick-Carthew If I follow that procedure then I create a empty Excel file.
              DerRoteBlitz 1 Reply Last reply
                DerRoteBlitz
                DerRoteBlitz
                DerRoteBlitz
                @Peter-Bijnsdorp
                Good morning,
                I tried it as well, the CSV and the OV2 files are empty.
                • Nick Carthew
                  @Hanza-0 @Peter-Bijnsdorp
                  Sorry, I gave the wrong information, here are the correct instructions:
                  Open a new route and name it with the name that you would like for your POI list.
                  Position a POI at each location that you want a POI.
                  To do this, go to POIs and open the Manage tab, click Add and click on the map where you would like your POI positioned and give your POI a name.
                  • Peter Bijnsdorp
                    Peter Bijnsdorp
                    Peter Bijnsdorp
                    Thanks for the last correct description for making a Poi set. I ran it and it works perfectly, a very welcome feature.
                    Greetings Peter
                    • Hanza 0 Hanza 0
                      @Hanza-0 how did you manage your collection of club members now. Are they in an Excel document or otherwise?
                      MRA Lifetime Gold
                      Hanza 0
                      Hanza 0
                      RideOnWithFriends
                      RideOnWithFriends
                      Peter Bijnsdorp
                      Peter Bijnsdorp
                      DerRoteBlitz
                      DerRoteBlitz
                      • Map lock
                        tfdahazellgmail.com
                        tfdahazellgmail.com
                        93
                        2.1k
                        Gerard van der Veer
                        Gerard van der Veer
                        443
                      • Route exporteren uit beta
                        87
                      • Uitnodiging
                        Hanza 0
                        Hanza 0
                      • Beta abonnement
                        Jeroen ekkel c
                        Jeroen ekkel c
                        125
                      • V6 - Track Navigation
                        BMcG
                        BMcG
