  4. unable to calculate route
27 Posts 3 Posters 9.1k Views 2 Watching
  • Patrick 33 Patrick 33
    @Corjan-Meijerink Good morning, For your information, I just reset the tablet settings and everything works again on the myroute application.
    @Patrick-33 great! 🙂
      @Patrick-33, thanks for reporting back. Did you have any security, anti-virus or, privacy apps installed previously by any chance?
      Patrick 33
      Patrick 33
      Patrick 33
      @Con-Hennekens said in unable to calculate route:
      Yes, it has BitDefender on it.
        @Patrick-33, I think it will be mighty interesting if you reinstalled Bitdefender after resetting your tablet, and if your testing was done prior of after that. Bitdefender probably has some code that could intervene with access to the HERE servers. For DuckDuckGo this has already been proven less or more...
        Patrick 33 1 Reply Last reply
          Patrick 33
          Patrick 33
          Patrick 33
          wrote on last edited by Patrick 33
          #24
          I uninstalled and reinstalled BitDefender and yes, it is the problem.
          Unable to calculate route.
          I'm uninstalling Bit defenbder at the moment.
          Edit : And it's persistent because even after uninstalling BitDefender, I still have to reset the settings.
            @Patrick-33 said in unable to calculate route:
            Thanks for trying and reporting. If you want to keep using BitDefender on your device, I assume there are methods for whitelisting specific apps in some controlpanel. You might get some help with that through their customer support or forum.
            @Corjan-Meijerink, Looks like we have another culprit to add to the list 😉 . Maybe it is wise to check of the HERE (or MRA?) servers are on some blacklist that is used by some of the AV or privacy software companies?
              Patrick 33
              Patrick 33
              Patrick 33
              #26
              Yes I think it is possible to configure BitDefender, but at the moment we are traveling and don't really want to play around with the configurations. Too much need for MRA at the moment.
              We will do without BitDefender.
                @Patrick-33, sure, keep it for another time 😉 Enjoy!
                Patrick 33
                Patrick 33
                • MRA Studio export speed
                • Hiya from UK
                  Russ Nattrass 1
                  Russ Nattrass 1
                • geeft routepunt niet weer
