  2. [Beta] The MyRoute-app
  4. A to B navigation not working
4 Posts 2 Posters 80 Views 1 Watching
  • David Bonner Offline
    David Bonner
    Yesterday I used Navigation to give me a direct route to a location from my Favourites. All worked as expected until I pressed the yellow arrow after which the map β€˜home’ screen appeared with the route shown as a blue line, but with no guidance, speed limit, distance etc. In fact the navigation did not function at all during my journey, the arrow simply tracked my position as it would with the home screen.
    I checked this again today and the same thing occurs, also if you enter a destination in the search box. Navigating a pre-prepared route however appears to be functioning correctly.
    IPhone 13, Nav version 4.0.8 - 224
    • David Bonner David Bonner
      Con Hennekens Offline
      @David-Bonner, It looks like you started a by foot or bicycle route instead of a car or motor route. There is no turn-by-turn navigation for by foot and bicycle routes. Those just follow the line on the base OSM map.
      David Bonner 1 Reply Last reply
        David Bonner
        @Con-Hennekens Ok, I can see my mistake now! Apologies for not realising this and thanks for putting me right πŸ‘.
          @David-Bonner, Mistakes are easily made. You are welcome!
          David Bonner
          David Bonner
          • opslaan naar plantomtom
            chris 18
            chris 18
          • Waypoint list for a long route ( ~50 t0 100 routing points) will not be show on the Android auto ridernav screen
            Stevedo 6 0
            Stevedo 6 0
          • Update 5.2.2 - Quick fix
            ginogino
            ginogino
            1.3k
          • scherm bevrirzing
            Leike Lodiers
            Leike Lodiers
          • Position Arrow
            Leike Lodiers
            Leike Lodiers
          • DMD-T665 as a Motorcycle Navigation Device – Long-Term Review
            Ioan Dragulescu
            Ioan Dragulescu
            10.3k
          • nieuwe Belgische gebruiker
            Leike Lodiers
            Leike Lodiers
          • Welke instelling
            Leike Lodiers
            Leike Lodiers
            392
