  4. no internet but.....
13 Posts 4 Posters 3.5k Views 2 Watching
  • Fred Gilbert
    Fred Gilbert
    Fred Gilbert
    Lets say you are faced with a major road closure. You are in the middle of nowhere without internet. You have the offline maps for the region you are in. It Should be possible to start a new route and save it to the phone and use offline maps. I had just enough intermittent internet to open the app but still couldn't make the route.
    paul69 Con Hennekens Fred Gilbert 3 Replies Last reply
    • Fred Gilbert Fred Gilbert
      paul69
      paul69
      paul69
      wrote on last edited by paul69
      hi @Fred-Gilbert
      i have a rugged tablet on which i use MRA for navigation on my motorbike. i always have it set to offline maps and UK maps downloaded.
      i do not have a SIM card in the tablet therefore do not have internet access, except if i use wifi at home or hotels.
      my tablet is in airplane mode almost all of the time, i can plan a route without switching airplane mode off or connected to wifi.
      what i mean is, put a destination in the search bar and let mRA do the rest, i am not talking about making a route with via/shaping points etc.
      what i do notice is that it is a little slower, so my point is it can be done without internet access.
      K1600 GTL
      Oukitel RT3
      iPhone 13 Pro, carpuride 702b
        @Fred-Gilbert, If you want to enter a destination without an internet connection, you need to put your app in Offline mode first.
        Fred Gilbert 1 Reply Last reply
          Fred Gilbert
          Fred Gilbert
          Fred Gilbert
          yes, of course.
          Now if I could just prevent the app from turning "offline" off when I'm not looking!
            yes, of course.
            Fred Gilbert
            Fred Gilbert
            Fred Gilbert
            @Fred-Gilbert
            Now I remember, the problem was that I could not create a new route from route lab while (no internet) offline. I was thinking if I could start a blank route & save it to the phone I should be able with "offline maps" to finish making the route.
              @Fred-Gilbert
              Fred Gilbert
              Fred Gilbert
              Fred Gilbert
              This post is deleted!
                Fred Gilbert
                Fred Gilbert
                Fred Gilbert
                  Fred Gilbert
                  Fred Gilbert
                  Fred Gilbert
                  @Fred-Gilbert The way I see it, you have to think like a developer to use this app effectively. I was having a problem zooming in to a map while offline. I went to "map folder" and discovered that none of the maps I had previously downloaded were present.
                  Con Hennekens 2 Replies Last reply
                    @Fred-Gilbert, You can not use route lab without internet connection. It is a WEB planner 😉 The button in the app opens an embedded browser view to the website. Im am not a developer, and I think most customers are not 😉
                    You can however set a destination by address, company name or favorite using the looking glass, also in offline mode.
                      @Fred-Gilbert said in no internet but.....:
                      Where did you find this "map folder"? Has it at all something to do with the MRA app? I have been looking for the mapdata myself some time ago, and could not find it quickly enough.
                        Fred Gilbert
                        Fred Gilbert
                        Fred Gilbert
                        I was referring to the settings section listing available offline maps.
                        I had a number off maps that had disappeared. I assumed that if there was no "X" next to them, it meant there was nothing there.
                        Con Hennekens RetiredWingMan 2 Replies Last reply
                          @Fred-Gilbert, ah, that explains. Do you have your maps written to an SD card by any chance?
                            @Fred-Gilbert there was a Here update a month or so ago that required an update and all previous downloads were removed.
                            paul69
                            paul69
                            Fred Gilbert
                            Fred Gilbert
                              Dae 0
                              Dae 0
                              11.3k
                            • Undo/Redo tool is hidden
                              b0hd1
                              b0hd1
                            • POI menu-taal afwijking
                              Albert van den Elsen
                            • Scenic route creation is not working.
