  3. [App-Beta] Announcements
  4. Endurance test MRA Navigation Next
6 Posts 3 Posters 113 Views 1 Watching
  • Michel van Hagen MRA-Founder
    Administrator
    Extreme test of 1052 km in almost 19 hours with various tips & tricks on how you can navigate wonderfully carefree with MRA Navigation Next!
    >> Read more
    Stanisław Siepermann- Ronald 2 Replies Last reply
    • Michel van Hagen MRA-Founder Michel van Hagen MRA-Founder
      >> Read more
      Stanisław
      Stanisław
      Stanisław
      @Michel-van-Hagen-MRA-Founder Interesting relation - thank you! There is one small part not translated to English, could you complete it?
      Regards
      Staszek
      Michel van Hagen MRA-Founder 1 Reply Last reply
      • Stanisław Stanisław
        Administrator
        @Stanisław Okay now?
        Stanisław 1 Reply Last reply
          Stanisław
          Stanisław
          Stanisław
          @Michel-van-Hagen-MRA-Founder One more:
          Regards
          Staszek
            >> Read more
            Siepermann- Ronald
            Siepermann- Ronald
            Siepermann- Ronald
            wrote on last edited by Siepermann- Ronald
            Heb met veel belangstelling je verslag gelezen. Met betrekking tot de melding op het Honda scherm 'wil je een headset pairen' even het volgende:
            Na het opnieuw starten van de motor en het verschijnen van de headset pairing moet je de Return-knop zo'n 20 tot 30 seconden ingedrukt houden. Hierna zie je inderdaad dat, in mijn geval de CarlinKit 4.0 gaat opstarten.
            De Apple Carplay werkt hierna weer als vanouds.
            I read your report with great interest. With regard to the message on the Honda screen 'do you want to pair a headset', the following:
            After restarting the engine and the headset pairing appears, press and hold the Return button for about 20 to 30 seconds. After this you will indeed see that, in my case, the CarlinKit 4.0 will start up.
            The Apple Carplay then worked as usual again.
            Honda NT1100DCT, iPhone 12Pro, CarlinKit 4.0
            • Siepermann- Ronald Siepermann- Ronald
              Administrator
              @Siepermann-Ronald said in Endurance test MRA Navigation Next:
              Bij mij ging dat vanzelf. Dus iPhone verbonden met Ottocast. Headset was leeg. Pairen met headset genegeerd en na ongeveer 20 seconden verscheen de route op het scherm. Maar zal jouw optie ook eens proberen een volgende keer.
              Stanisław
              Stanisław
              Siepermann- Ronald
              Siepermann- Ronald
              • Map Layers
                Martin White
                Martin White
                Michael 2v
                Michael 2v
