  4. Samsung s21 to nav6
Samsung s21 to nav6
2 Posts 2 Posters 814 Views
  • Colin Hodgkinson
    Colin Hodgkinson
    Colin Hodgkinson
    Currently on holiday and would like to plot a route and send it to nav6 .is there any way to do this direct from phone.
    • John Warner
      John Warner
      John Warner
      You need a micro USB to usb-c cable to connect the phone to the nav 6. As far as I know there is no wireless method.
      Connect the two devices then wait a while. Open "My files". The nav 6 should show as "Usb storage" or "usb storage 1". Below that is a sub directory called "Gpx". Export your route to a gpx file from mra. That should end up in "downloads". You now need to copy that file to the gpx folder then restart nav 6. The whole process is a bit tortuous. (I now use the bmw cradle - much easier)
      I tried the above with a nav 5 and S10 and it worked. Nav 6 isn't much different. (I used to have a nav 6).
      Hope that helps
      Colin Hodgkinson
      Colin Hodgkinson
      John Warner
      John Warner
        3.1k
      • Spoken notes are truncated
        Chris 4p
        Chris 4p
      • Navigating on NEX
        LluĂ­s Casals
        LluĂ­s Casals
      • v6, tankstation
        superg
        superg
