  4. Misses waypoints!
Misses waypoints!
5 Posts 4 Posters 1.7k Views 1 Watching
  • Gordon Lawson
    Gordon Lawson
    Gordon Lawson
    wrote on last edited by Gordon Lawson
    Hi,
    I've created a route in mra via the website which consisted of 4 waypoints. I then used the mra navigation app to navigate this route, but it missed out waypoint 2. Instead in calculated a direct route to the last destination - this just happened to have the other waypoints along this direct route.
    I used the route option instead of track this time, but a few days ago it did the same with a different route where I asked it to follow a track. This occurred when creating the route in mra on the web then exporting the route as a gpx file for use with Sygix.
    Am I doing something wrong? I have a 300 mile route set up for tomorrow with 12 waypoints that I must visit along the way and am not confident it is going to work!
    • Gordon Lawson Gordon Lawson
      Hi,
      @Gordon-Lawson If you must pass specific waypoints - make them a dedicated via point (the hand symbols).
      Turning off the auto skip functionality from the settings is also possible.
      @Gordon-Lawson said in Misses waypoints!:
      mra navigation app
      I do assume you are using the app called "MyRoute-app"?
      Gordon Lawson 1 Reply Last reply
        mra navigation app
        Gordon Lawson
        Gordon Lawson
        Gordon Lawson
        @Corjan-Meijerink said in Misses waypoints!:
        mra navigation app
        Thanks for your quick reply. I will change my waypoints (shaping points?) to via points and hope that fixes it. So what use are these shaping points if they are ignored?
        (Yes, I am using MyRoute-app)
        RetiredWingMan MotoCon 2 Replies Last reply
          mra navigation app
          @Gordon-Lawson the waypoints are not ignored. However, on occasion, the auto skip function may skip a waypoint before you have arrived at it. I've seen this but never actually had it affect my route.
            mra navigation app
            @Gordon-Lawson, DON'T! It wille effectively kill the auto-skip function. (and it is a lot of work too...) If you don't want auto-skip, just disable it in the settings (functional).
            Gordon Lawson
            Gordon Lawson
            • Route wordt afgesneden
              Wim Hompes
              Wim Hompes
              Herman Veldhuizen
              Herman Veldhuizen
              Pierre c
              Pierre c
            • OSM Routing with MRA
            • reuse pictures
