  4. Map problems and others
3 Posts 2 Posters 77 Views
  • Kudee
    Kudee
    Kudee
    Small tour today. Already at the beginning Message no Internet although available. Message cannot be acknowledged - route ended and restarted. On the way I noticed that the map is not fluent. It freezes and then jumps. Tested online and offline. Turn-by-turn directions are ok but map and arrow are way behind. This stupid compass, don't understand its function but depending on the orientation the map is displayed or not. Please remove it, it makes problems only. When I starta route in the middle I expect it to calculate the time to destination and not the whole route again as it seems.
    Positive: My battery was charged during the ride.
    My conclusion: The old app was not so stable but I never had map problems.
    Here seems to be asleep with the map update. Many round abouts are not on the map. Calimoto has updated maps!
    Thanks and sorry for the criticism, but it's May and the season has started 🙂Screenshot_20230506_132422_com.cloudmax.myrouteapp.jpg Screenshot_20230506_112618_com.cloudmax.myrouteapp.jpg Screenshot_20230506_112616_com.cloudmax.myrouteapp.jpg Compass-2.jpg Compass-1.jpg Starting not at the beginning of the Route.jpg
    • Kudee Kudee
      @Kudee no worries about giving criticism.
      If you don't have internet available the maps can't be loaded and route calculation will fail. You said you cannot acknowledge the prompt, what do you mean with that? If switching to offline mode, you obviously need to have the maps downloaded.
      The compass? Just tap it to cycle between north up (fixed camera) and the dynamic camera (automatic zoom, heading up).
      Kudee 1 Reply Last reply
        Kudee
        Kudee
        Kudee
        @Corjan-Meijerink Thank you for the feedback. Something is wrong with the map.
        On the road I noticed that the map is not fluid. It freezes and then jumps. Tested online and offline. Turn-by-turn directions are ok, but map and arrow are way behind. Another user posted the same thing. Again about the compass. Depending on when I click on it I see the roads or not, very specific. I could not confirm the message "No internet" go offline. Restarting the app was the solution. But please look at the problem with the map, it's not good at all that it doesn't show the current position! Thank you
        Kudee
        Kudee
        • Strange translation
        • Undo/Redo tool is hidden
          b0hd1
          b0hd1
        • Crazy routing
          10.4k
          b0hd1
          b0hd1
        • Which route is shown?
