  3. Some new suggestions
2 Posts 2 Posters 553 Views
  • Ronni
    Ronni
    Ronni
    Just a few "little" suggestions, all concerning smartphone usage.
    Greetings, Ronni
    1. I would place the button that indicates the waypoint to be skipped on the right side of the hand. The symbol shows a right edge and that fits better on the right side of the hand. Overall, only a design point, not so important .
    1. I can't remember exactly, but has it always been the case that the settings block only took up part of the screen and not the whole screen?
    1. As already mentioned in another post, the switch positions can hardly be seen in sunny light. The whole picture is kept very dark. Maybe you can replace the blue circle with a lighter one (e.g. yellow here)?
    1. Another design point: If you want to show "Routendetails anzeigen", the button is placed below, If you now want to go back and want to click "Routendetals ausblenden", the button is at the top. Can't you leave it in the same place like a switch? It doesn't matter if it's up or down.
    Samsung Galaxy A56 5G
    Android 16
    One UI Vers. 8.0
    Carpuride W712D
    Silverfox BT Cntroller H1+
    • Ronni Ronni
      Greetings, Ronni
      @Ronni Thanks for the feedback!
      1: We'll see what we can do. It was placed on the left side intentionally as we believed the right side would be a bit too close to the edge of the screen.
      2: This was always the case 🙂
      3: We'll check and improve the styling!
      4: I don't think this is something we can change easily but thanks for suggesting anyway!
      Cheers 😃
      Ronni
      Ronni
        456
      • Myrouteappstay
      • Track colors by section.
        Rolf Engelsman
        Rolf Engelsman
        Marcel Versluis
        Marcel Versluis
