  4. Black screen at low speeds
9 Posts 3 Posters 119 Views 1 Watching
  • UltraStar
    UltraStar
    UltraStar
    iPhone 11P, ver. 16.2; MRA 3.2.6 - 147. I think someone mentioned that issue before; I discovered it today on my ride.
    First, I did not see it happening when navigating a route.
    Second, I did not see it happening when riding using 2D view.
    Third, this happened to me only when I was tracking my location (recording and not recording) using 3D view. When I was slowing down to below about 20 mph, the screen was turning black, and returning back when I picked up the speed above about 20 mph.
    I thought about the zoom; in 2D there is no zoom-in on the map when you slow down at the intersection, etc. so the screen works fine. In 3D, the map is zoomed-in when you slow down, and that's when the black screen shows up.
    So, when I was stationary, I have zoomed in on the map manually and voila, the screen turns black every time you reach certain level of zoom-in no matter if it is 2D or 3D view.
    • UltraStar UltraStar
      @UltraStar Thanks for reporting! I can indeed confirm that this is a issue I did not yet know about 😉
      Based on my observation you must be using the non-vector maps or the satellite image map. Please select a 3D map layer to allow a higher zoom level. I'll make sure this issue will be fixed in the next Beta update.
      UltraStar 2 Replies Last reply
        UltraStar
        UltraStar
        UltraStar
        @Corjan-Meijerink Now you got me. How to check what type of the maps am I using? Is there a place to select the type of maps?
        I just start the application and go with the flow. 🙂
          UltraStar
          UltraStar
          UltraStar
          @Corjan-Meijerink Well, I think I get what are you saying. I never payed attention to the 3D selection on the map layers screen. When I clicked on the 3D selection, the black screen does not happen.
          Thank you.
            Thank you.
            Steve Lynch
            Steve Lynch
            Steve Lynch
            @UltraStar
            UltraStar 1 Reply Last reply
            • Steve Lynch Steve Lynch
              @UltraStar
              UltraStar
              UltraStar
              UltraStar
              @Steve-Lynch I got that. Thank you.
              • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
              • Corjan Meijerink Corjan Meijerink unlocked this topic on
                Happy to hear you found the more detailed premium maps 😉 Still, the issue will be fixed! Thanks a lot for sharing
                  UltraStar
                  UltraStar
                  UltraStar
                  @Corjan-Meijerink Thanks Corjan. I have assumed that HERE is a default map selected for the navigation from the beginning. How many definitions of "assumption" do you know... 🙂
                  The Next is coming along really nicely.
                    @UltraStar Hahah, indeed. Happy to hear you are enjoying the Beta.
                    When using the actual turn-by-turn navigation, there is only one map available and that is HERE 🙂
                    UltraStar
                    UltraStar
                    Steve Lynch
                    Steve Lynch
                    • Strange translation
                    • Crazy routing
                      b0hd1
                      b0hd1
                    • Foutmelding In MRA Next
                    • Kort voorstellen
