  3. ERROR planing route too long
9 Posts 3 Posters 1.5k Views 1 Watching
  • Andrzej 0
    Andrzej 0
    Andrzej 0
    **HI **I have problems vith calcualted route from Scotland to Sewastopol in Crimea due to my motorcycle tripp next year to CRIMEA and DNR , LNR . Iknow route is very loong and i have couple of days for this road and stop over the night. Unfortunettely even if i have 6 days route vith braks over the night Route app NOT PLANING TRIPP. For example distance 10 mile before Turkish border to Turky border i have info The route calculation seems to take very loong .........
    well 20 miles is too long ???????????????? WHAT WRONG WITH THIS APP ??????
    Maby admin fix problems . Cheers Andrzej
    • Andrzej 0 Andrzej 0
      @Andrzej-0
      Would you please specify the locations you used.
      With that we can try to reproduce this situation and hopefully find a solution.
      Andrzej 0 2 Replies Last reply
      • TorqueRider TorqueRider
        @Andrzej-0
        Andrzej 0
        Andrzej 0
        Andrzej 0
        This post is deleted!
          @Andrzej-0
          Andrzej 0
          Andrzej 0
          Andrzej 0
          wrote on last edited by Andrzej 0
          @Jack-van-Tilburg For example DFDS Ferry Terminal DUNKERQUE to border controle point between Bulgary and Turky ( 1 mile after border on Turky side ) is HOTEL ( LONDRA INN ) . Even if you planing this route for 6 days you can planing to border only . After border info THE ROUTE CALCULATION SEEMS TO TAKE VERY LOONG .
          Badawy the same ituation is for other side EU continent if you planing tripp from LIEPAJA ( LATWA ferry terminal ) to Moscow via border point at TEREHOVAS is the same info on too long route . But if you planing to border check point as one route and after check point 5 miles away as second route thats ok . But 5 miles no route planing .
          EXAMPLE
          DFDS FERRY TERMINAL DUNKERQUE to Sofia you canplaning tripp but the same planing after Sofia to SHELL 22130 KEMAL EDIRNE TURKYE just after border is info The route calculation seems to take very long You can try resolving this by shortering your route or by adding a waypoint between your current waypoints .
          its OK iam understand but SOFIA is waiting point where i have night and from SOFIA to border its only 296 km . From Dunkerque ferry terminal to Sofia is 2200 km and planing ok vith no any problems , but 296 km between Sofia to Turkye border is TOO LONG DISTANCE ??????
            EXAMPLE
            @Andrzej-0
            I have used the indicated waypoints and only run into problems with SHELL 22130 KEMAL EDIRNE TURKYE.
            But I solved that by using the Here map and enabling the "Disable seasonal closures" option.
            By the way: If you want to use the TomTom map, you will have to take into account that the options "Hilness & curves" and "Curves" work for routes with a maximum length of 900 kilometers.
            the above options are only available for Gold users.
            Steve Lynch Andrzej 0 3 Replies Last reply
              @Andrzej-0
              Steve Lynch
              Steve Lynch
              Steve Lynch
              @Jack-van-Tilburg said in ERROR planing route too long:
              Thanks @Jack-van-Tilburg.
              Every day is a school day, I wasn't aware there was a limit.
              I use the Tom Tom Curvy/Windy Routes all the time and map them to the Here Map with Waypoints.
              I guess I've never created a route that long before.
              • Steve Lynch Steve Lynch
                @Steve-Lynch
                  @Andrzej-0
                  Andrzej 0
                  Andrzej 0
                  Andrzej 0
                  @Andrzej-0
                    @Andrzej-0
                    Andrzej 0
                    Andrzej 0
                    Andrzej 0
                    @Jack-van-Tilburg TANK YOU SOOOOO SOOOOO MUCH FOR HELP All is working you save my life and my tripp. Have good day and MERRY XMAS from Scotland .
                    Steve Lynch
                    Steve Lynch
                    Andrzej 0
                    Andrzej 0
                    • Upgrading from Zumo XT to XT2
                      Thomas Neumeyer
                      Thomas Neumeyer
                      3.7k
                      Robineke
                      Robineke
                      226
                    • How to plan correctly
                    • Offline Mode function
                    • Brittany routes
                      Tony 13
                      Tony 13
