  3. Importing routes from RouteYou
2 Posts 2 Posters 704 Views
  • Herman Guns 0
    Herman Guns 0
    Herman Guns 0
    Hello,
    When I import a route gpx file from RouteYou it is a mess in MRA. When I convert the route first from route to a track before importing in MRA the route is fine, but I lose all the waypoint.
    Q : is there a work-around to import routes from RouteYou in MRA ?
    Thank.
    Herman
    • Herman Guns 0 Herman Guns 0
      Hello,
      Thank.
      Herman
      @Herman-Guns-0
      MRA and Routeyou are two different programs. It is inevitable that you will get differences and you will have to edit a route in MRA. This is best done if you also open the original track in the map with the route.
      Herman Guns 0
      Herman Guns 0
      • Move a GPS point on the map
        Rolf Engelsman
        Rolf Engelsman
      • Guida Libera
      • eCharger and Range
