  2. Routes & Tracks
  3. Ordering several routes
3 Posts 3 Posters 888 Views
  • Mick k
    Mick k
    Mick k
    wrote on last edited by Mick k
    I have created several routes for a tour I am planning. I would like to display them in the order I’m going to use them. So in myrouteapp I prefixed each route with a letter. So far so good. However when I view the same list in the Navigation App the order has changed.
    Is there a way of seeing the order in the same way in both applications?
    A8F4411A-845A-4F24-82C4-75552703D2DB.png A165F5CA-FC87-415F-BCF1-9A16D152CEDD.png
    Herko ter Horst Nick Carthew 2 Replies Last reply
    • Mick k Mick k
      Herko ter Horst
      Herko ter Horst
      Herko ter Horst
      @mick-k Sadly, no. The feature has been requested before (here, for example), but so far it's not available.
      • Mick k Mick k
        @mick-k There is a workaround to help find routes more quickly and that is to create an event and add the routes that you plan to use into the event. Open the event in your MRA Nav app and all of your planned routes are there to use. Not the best solution but if you have 100s of routes in your MRA library it certainly helps.
        Herko ter Horst
        Herko ter Horst
        Mick k
        Mick k
        • In het kort......
        • Route probleem
