  4. Improve Menu Font Size and Readability
8 Posts 4 Posters 1.6k Views 3 Watching
  • benet_73
    benet_73
    benet_73
    I would like to ask whether there is currently an option, or if it could be considered in the future, to increase the font size of the menu within the app.
    In my case, the menu text feels quite small and, as we get older, it becomes a bit harder to read comfortably.
    I also wanted to ask if it would be possible to hide or reduce elements such as “Good evening” and “Start now”, as these texts are significantly larger than the rest of the menu, while the most important menu options are displayed with much smaller text.
    Overall, the idea would be to improve readability and accessibility, either by:
    Allowing font size adjustments for the menu, or
    Creating a better visual balance between large header texts and the main menu items.
    Thank you very much for your great work and for considering this kind of feedback.!
    Ducati MTS V4S - BMW R 1300 GS
      Hi, font size adjustment should be possible via your phone setting, there is nothing inside the app for this.
        @Jörgen @benet_73 No! The app has a fixed fontsize you can’t adjust through the OS of your device (although, on iOS you can’t!)
        • Rob Verhoeff
          @Jörgen @benet_73 and on Android that doesn’t work also… sorry about that.
          • benet_73
            benet_73
            benet_73
            Thanks for the replies.
              Ok, understand.
                We have seen multiple strange things happen when you enlarge the font settings from within the phone's system settings. So it cannot be advised to do so I am afraid.
                • benet_73
                  benet_73
                  benet_73
                  Would it be possible to increase the font size of the app a little? It's a suggestion to improve the app. Greetings to all.
                  benet_73
                  benet_73
                    Thomas Schäfer
                    Thomas Schäfer
                  • Route wordt afgesneden
                    Pedro de Cleen
                    Pedro de Cleen
