New beta! 5.0.3 (447)
hopelijk krijg ik nu niet tig meldingen. op een aantal tablets geinstalleerd zowel ios als android en op aantal telefoons ios en android. hopelijk word bij upgrade van app status gelijk offline gemaakt zodat ik alleen met 2 items kan inloggen op app. we gaan het ervaren. op android trouwens beta en op ios gewoon.
Hi everyone!
It is time for a lovely new beta.
Not the most exciting update for you but definitely for us
Device management
This is the core aspect of this update.
Unfortunately we are seeing a massive amount of account sharing going on.
At MyRoute-app we try our hardest every single day to be customer oriented and keeping our prices low. As of this year our base prices for subscriptions had to be increased (for the first time since 2021) and because of new contracts with our suppliers we also have to implement a device limit per subscription.As we now pay per active phone we cannot (ignorantly) allow users to use our app on an unlimited amount of phones. As of this update we allow a maximum of 2 devices to be used at the same time. When exceeding this limit (3 devices) you will be presented a beautiful interface in which you can logoff another device. After doing so, you can use your current phone again
Some important notes:
- Excessively switching between multiple phones will lead to an automatic warning
- Attempts to use way too many devices (4) at once will lead to an automatic block
Our terms & conditions will be updated appropriately.
Simply put: times of sharing your account with big groups of friends or your club are over, sharing with your partner / personal use on a few devices is still allowed.Note for beta testers: being a beta testers does not mean you are allowed to share your account but if for (proven) testing you wish to use more devices, simply contact our support department.
SSO fixed
Signing into the app using a SSO authentication method (such as Apple or Google) was broken. Luckily this has now been fixed!
Link and file opening
Opening links and files with the app has always been possible.
In this update the stability of these features has been improved to ensure it works as expected when the app is in any state (such as terminated / in the background / opened).Minor fixes and stability improvements
Many small issues that are not relevant to mention here have been fixed.
Also we fixed a few errors that would result in route calculations failing.
Finally a few critical CarPlay / Android Auto errors have been solved and we added a bit more logging to investigate some persistent issues a few users have.What's next
Slowly but surely we are transitioning to a more focused dedication on the website.
In the next update 5.1 we will:- Aim for solving all stability issues CarPlay and Android Auto
- Add highly requested features to CarPlay and Android Auto
- Major technical internal updates
Cheers,
Corjan@Corjan-Meijerink Did Some testing of the new Beta.
I saw that the spinning map issue is not yet solved. In both navigating a route and the free drive mode there’s still a problem. When I comes to a complete stop the map turns in the north direction and the position marker moves direction north. If I was on a road with separated lanes the position marker will move to the lane that is heading north. The north direction of the dynamic mode camera view will then turn witch will be actually not north. I haven’t seen that in the previous versions. So the spin of the map is actually turning the map facing north.Another thing that I’ve noticed was when the notification of a speed camera pops up and your speed is over the Max speed the pop-up turns red, great feature. Maybe it was already like this but I haven’t noticed it before
Ein Vorschlag: s. Bild, so war das da gemeint, denn ich finden den Hinweis das beim abmelden Dinge gelöscht werden schon sehr wichtig !
Vorschlag:
Original, hier ist die Auswahl zwischen "Meine Geräte" und "Abmelden" zu dicht beieinander. Ein Hinweis das was gelöscht wird fehlt auch !
@Bouke-Ent said in New beta! 5.0.3 (447):
Je heb een limiet van drie apparaten waarvan er twee tegelijkertijd ingelogd kunnen zijn. Wissel jij vaker van toestel dan van sokken? Pas als je met het derde apparaat wilt navigeren dan krijg je op dat apparaat de melding om je af te melden van één van je andere apparaten. En dat vergt bijna geen extra handelingen...
