  4. “Back” button is hidden
5 Posts 4 Posters 1.9k Views 2 Watching
  • Tuxi
    Tuxi
    Tuxi
    Hello everyone,
    When I'm in planning mode, the back button is often covered by the progress bar at the bottom (I'm not sure what it's called).
    This doesn't always happen, but it bothers me when I'm planning.
    Is it possible to disable this bar at the bottom?
    Best regards!
    Peter Zehentreiter Rob Verhoeff 2 Replies Last reply
    • Tuxi Tuxi
      Hello everyone,
      Best regards!
      wrote on last edited by Peter Zehentreiter
      @Tuxi Which control method have you set on your Android phone?
      Gesture control or 3-button control?
      Try changing this and check again whether the back button is still covered.
      https://share.google/A9RKevwf7saeMgz8q
      Just realized that you probably meant the Website...
      Sorry for confusion from my side.
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      • Tuxi Tuxi
        Hello everyone,
        Best regards!
        @Tuxi The website is currently being completely redesigned. I don’t yet know what it will ultimately look like, but since the current website is based on a platform that can no longer be updated, I can easily imagine that this issue will no longer occur once the new site is live. Until then, it’s a matter of being patient and, above all, not letting it bother you. 😉
        • Tuxi
          Tuxi
          Tuxi
          Great, thank you very much.
            The key combination CTRL-Z or CTRL-Y does the same!
            Tuxi
            Tuxi
              460
            • Myrouteappstay
            • Track colors by section.
              Rolf Engelsman
              Rolf Engelsman
              Marcel Versluis
              Marcel Versluis
