  4. Car Play new features request
5 Posts 3 Posters 1.5k Views 1 Watching
  • Alliston
    Alliston
    Alliston
    Hello
    Could you add the following features -
    being able to open search for say petrol etc while on a route?
    add the option of switching to offline mode from carplay screen
    add a recent list to be able to choose a route without going down sub folders
    add a way point list to the skip waypoint button, or even better be able to select a waypoint from the screen when you have zoomed out or used the whole route button.
    Thanks
    • Alliston Alliston
      Hello
      Thanks
      @Alliston, beware... 😉
      There is a function that shows the closest gas station on your route. Besides that, there is an "Add waypoint" function in the 3-dot menu, which opens the search window.
      There is not even such a function in the app, while navigating. Why would you want to have that in carplay?
      Just tap the magnifying glass, all your recents are in there, routes, single destinations, favorites, all of them
      That is WAY to dangerous, and since that tile is meant for being able to use while driving, that is not going to happen! There is however a waypoint list in the 3-dot menu, which you can use to skip to, with a long-press.
      Zoom to anywhere you like on the map, and long-press any waypoint you wish to target. If you long-press the compass icon, you will zoom out to see the whole route if that helps.
      You must be a very lucky man, seeing ALL of your desires already implemented in the app... 😉
      May I suggest looking at the support page? https://www.myrouteapp.com/support
      The manual has just been update to match the new version 5 of the app.
      Alliston 1 Reply Last reply
        Alliston
        Alliston
        Alliston
        @Con-Hennekens thanks for your response, my questions were all based on the car play interface, .apologies for not mentioning in all of the requests. Alliston
        • Alliston Alliston
          @Alliston, That was an important omitted piece of information indeed 😉
          Some updates will definitely be done on the CP and AA GUIs, but you probably know that restrictions forced by Apple and Google concerning safety and distraction are in place.
          • Bacus
            Bacus
            Bacus
            1. I wish I had a force sync button on AA screen, sometimes it shows a refresh icon, but never sync again. When this happen I need to exit the app, start MRA on my phone, resume navigation, then start the app on AA, but sometimes nothing helps just stop the bike, turnt it off, then after a few second turn on, chigee cold restart, and voila. Insted this I need a resync function.
            2. It would be nice an option beside online and offline navigation mode, online if not possible switch to offline (I maps already downloaded).
            3. A quicker way to skip waypoints, or better to have a function "continue to the next waypoint from the position", so it can skip as many waypoints as it needs.
            4. on AA autozoom could work better, maybe somehow the wheel on bmw default be the zoom function, or a dedicated on screen button, to reset view (orientation, zoom, etc) to the default.
            Alliston
            Alliston
            Bacus
            Bacus
            • F014 WP Numbering illogical
            • Map colours and side roads
            • OSM Routing with MRA
            • GPX POI Editor
              Pierre c
              Pierre c
              Adrian Avram
              Adrian Avram
