  3. POI’s
POI’s
2 Posts 2 Posters 866 Views 2 Watching
  • Dave 1u
    Dave 1u
    Dave 1u
    Apologies if this subject has been covered but I’m fairly new to MRA. If got my head round the creation of routes with via points and shaping points abs fortunately I have a Garmin Zumo XT which can handle the two different types of waypoints. What I’d like to be able to do is ADD a POI. I know that I can select a POI and utilise it as a waypoint and save it as a POI but if I’m aware of a good wild camping area for example, I’d like to add that as a POI to my route.....is this an option? If not can it be please?
    • Dave 1u Dave 1u
      @Dave-1u You can add any point in the map as a POI inside the specific route. I say explicitly inside that route, because without further actions these POI's are not present in a new route unless you save these locations as favourites too or create a custom group of POI's through a external file.
      You can add an own POI by clicking the "Beheren=Manage" tab in the POI menu:
      After clicking the "Toevoegen=Add" button you can select any point on the map, click on "POI Plaatsen=Place POI" and a POI popup menu will ask for a custom name:
      Type custom name or simply use POI and click "Accepteren=Accept":
      Now the POI has been created. Unfortunately the icon itself cannot be changed.
      Now you'll find the custom POI in the same "Beheren=Manage" tab of the POI menu:
      Dave 1u
      Dave 1u
        3.1k
      • Spoken notes are truncated
      • Navigating on NEX
        Lluís Casals
        Lluís Casals
        Chris 4p
        Chris 4p
      • v6, tankstation
        superg
        superg
