Elevation profile: cursor that follows the route on the map
Hi,
In many hiking applications there is a very useful feature that makes it easy to visualize how the elevation changes along a route.
It would be extremely useful if, while moving the mouse cursor along the elevation profile, a marker on the map would simultaneously move to the corresponding GPS position on the highlighted route.
This would make it much easier to identify where the steepest climbs, descents, or most demanding sections of the route are located.Thanks
Hello , It’s already here
Hi,
@Corrado-Miniati Do you mean like this?
About altitude profile, there is an option on old planner that allows to mark route sections above certain limit. This option is missed on new planner.
Can be added?
Like this:
Regards,
@Nick-Carthew
Hi Nick, yes, that's exactly it.
However, it isn't visible on the map when you're looking at a more detailed section (see screenshot below).
It's useful when you view the entire route, but not for the detailed view, which is ultimately the most useful one.
It would be very convenient if, after zooming in on the map and then activating the elevation profile, the cursor automatically positioned itself on the section of the route currently being displayed.
Thanks
@Nick-Carthew
Thanks
@Corrado-Miniati My sceenshot shows the map is fully zoomed in. The altitude marker moves in increments of 0.1 of a mile (about every 160 metres) so when you are zoomed in close it is difficlt to see.
I'm attaching the map with a 300 m resolution.
The cursor does not appear; it is probably positioned somewhere along the route but is not visible in this view. -
The cursor does not appear; it is probably positioned somewhere along the route but is not visible in this view.@Corrado-Miniati
Strange, even on my iPhone I can use the elevation chart.
@Corrado-Miniati
@Nick-Carthew
It is not visible on my Windows PC -
I figured it out thanks to these posts. Intuitively after opening the elevation window I tried clicking on the road to see the elevation at that point, but that did nothing; eventually I discovered that clicking on the elevation chart revealed the matching spot on the road. I wonder whether others make the same mistake in which case the user interface needs some thought.
Would it be helpful to display the via points along the X axis of the elevation chart?
