  4. Logon not recognised on App
6 Posts 2 Posters 41 Views 1 Watching
  • Nick Dawson
    Nick Dawson
    Nick Dawson
    wrote last edited by
    Hello,
    Using an android device (which I normally use successfully) and my first attempt to logon to the new app informed me that it did not recognise my credentials.
    I went to chrome (on the same device) and logged onto the planner to write this.
    This is my first logon but my username and password work fine on the planner and I have already modified routes and explored the system.
    The username and password are correct.
    Nothing urgent as I was only looking at what changes there are ( I like the new splash screen btw).
    Nick
    • Nick Dawson Nick Dawson
      Hello,
      Nick
      @Nick-Dawson, Your credentials for the new planner may differ from the old planner. If you step to the new platform in the app, you need to use the credentials for the new planner.
      • Nick Dawson
        Nick Dawson
        Nick Dawson
        Hi and thank you for replying.
        My credentials are different and I entered the new details (which I also enter for MyRouteApp Next).
        It may simply be a blip and I will give it a go again next week.
        • Nick Dawson
          Nick Dawson
          Nick Dawson
          wrote last edited by Nick Dawson
          I tried clearing all cached dafaults on the app and logging in again but it still does not recognise my credentials.
          I hasten to add that the username and password are for MyRouteApp Next and I access the web version including this very forum with those same credentials.
          Is there a break in the links between MyRouteApp Next (web version) and the application?
          Are usernames and passwords parsed through correctly between the two?
          Did my previous subscription to the application automatically move through or/ does something need done to make that happen?
          I am sure that the answer is straightforward but it is going to need some investigation..
            @Nick-Dawson, Have you tried logging in with your old planner credentials? If that works, you did not flip the app to the new planner yet.
            Nick Dawson 1 Reply Last reply
              Nick Dawson
              Nick Dawson
              Nick Dawson
              @MotoCon hi,
              Yes I tried that too.
              It is definitely the new account with the new loading sequence of the waypoints instead of the older sequence.
              Nick Dawson
              Nick Dawson
              • Log in
                Rod Sydenham
                Rod Sydenham
                51
                Emanuele 5
                Emanuele 5
                76
                BMcG
                BMcG
                Tim Verhaaf
                Tim Verhaaf
                smfollen 0
                smfollen 0
              • The padlock icon is missing from my mobile phone
              • Not enough map view visible
                Giancarlo e
                Giancarlo e
