  2. MRA Routeplanner Next Beta
  4. Adding default break times for viapoint icons
5 Posts 2 Posters 13 Views 2 Watching
  • Corrado Miniati
    wrote last edited by
    Hello,
    When planning routes, I consistently use the same default break durations for certain types of viapoints, for example:
    • Fuel: 10 min
    • Restroom: 15 min
    • Food: 60 min, etc.
    Instead of having to manually enter these same break times every single time, would it be possible to set a default break duration for each type of viapoint icons?
    Thanks a lot
    • Corrado Miniati
      Perhaps it would also be possible to customize the color of the icons.
      • Jörgen
        This post is deleted!
        • Jörgen
          Just click on the color.
          • Corrado Miniati
            Sure, if it’s already the color you want, you don’t have to do it.
            • Log in
              Rod Sydenham
              Rod Sydenham
              43
            • Snelmenu / Quick menu
            • AI pricing is too high
              Emanuele 5
              Emanuele 5
            • Library Structure
              John Matthews 0
              John Matthews 0
              Juudje39
              Juudje39
              Andy Beviere
              Andy Beviere
              1.7k
            • Restriction on scenic length?
              Jeroen ekkel c
              Jeroen ekkel c
