<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding default break times for viapoint icons]]></title><description><![CDATA[<p dir="auto">Hello,<br />
When planning routes, I consistently use the same default break durations for certain types of viapoints, for example:</p>
<ul>
<li>Fuel: 10 min</li>
<li>Restroom: 15 min</li>
<li>Food: 60 min, etc.</li>
</ul>
<p dir="auto">Instead of having to manually enter these same break times every single time, would it be possible to set a default break duration for each type of viapoint icons?</p>
<p dir="auto"><img src="/assets/uploads/files/1794028203881-e709210e-df80-4184-8c8e-044573486157-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="442" height="346" /></p>
]]></description><link>https://forum.myrouteapp.com/topic/12421/adding-default-break-times-for-viapoint-icons</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 08:13:27 GMT</lastBuildDate><atom:link href="https://forum.myrouteapp.com/topic/12421.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Nov 2026 05:12:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding default break times for viapoint icons on Sat, 07 Nov 2026 07:47:21 GMT]]></title><description><![CDATA[<p dir="auto">Sure, if it’s already the color you want, you don’t have to do it.</p>
]]></description><link>https://forum.myrouteapp.com/post/88097</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88097</guid><dc:creator><![CDATA[Corrado Miniati]]></dc:creator><pubDate>Sat, 07 Nov 2026 07:47:21 GMT</pubDate></item><item><title><![CDATA[Reply to Adding default break times for viapoint icons on Sat, 07 Nov 2026 07:45:08 GMT]]></title><description><![CDATA[<p dir="auto">Just click on the color.</p>
<p dir="auto"><img src="/assets/uploads/files/1794037492254-13ceb866-b2e2-4ad4-af30-49a8608b81e9-image.jpeg" alt="image.jpeg" class=" img-fluid img-markdown" width="504" height="690" /></p>
]]></description><link>https://forum.myrouteapp.com/post/88094</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88094</guid><dc:creator><![CDATA[Jörgen]]></dc:creator><pubDate>Sat, 07 Nov 2026 07:45:08 GMT</pubDate></item><item><title><![CDATA[Reply to Adding default break times for viapoint icons on Sat, 07 Nov 2026 06:22:48 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps it would also be possible to customize the color of the icons.</p>
]]></description><link>https://forum.myrouteapp.com/post/88089</link><guid isPermaLink="true">https://forum.myrouteapp.com/post/88089</guid><dc:creator><![CDATA[Corrado Miniati]]></dc:creator><pubDate>Sat, 07 Nov 2026 06:22:48 GMT</pubDate></item></channel></rss>
