Bar Buttons problems
Hi,
I had problems with my Bar Buttons yesterday during my trip with the new version on Android.
The input setting is still set on BarButtons.
The problem is mainly with the zoom function.
Sometimes nothing happens while using Zoom; sometimes only 2-3 steps in one direction.
Very strange behavior.I will try to reproduce today and try to record it.
I think I've already fixed this in the next beta version.
Let me know if still there after the coming update (today is my guess) -
Sounds good, thank you. I went crazy yesterday.
You're always a bit crazy right?
I used to be normal. But it was boring.
@Jörgen we have a Dutch saying: "Doe maar normaal, dan doe je al gek genoeg".
Translating to: "Act normal, that's already crazy enough". -
Hi,
I’m not sure if this is related to the same problem.I used the bar buttons again on my ride today. At first, everything was fine.
After a long break, I couldn’t open the menu (Code N) any more.
Instead, when I pressed the C button (Code C), this screen appeared?
That’s actually supposed to change the view (like with the compass).
There is still something wrong/strange with the zoom via the BarButtons.
Sometimes the zoom works for 3–4 steps and then stops. You can keep pressing the button, but nothing happens. If you then touch the screen and move the map a little, the zoom suddenly starts working again.
