  4. Icon and text size for the next waypoint
2 Posts 2 Posters 216 Views 2 Watching
  • Torrealarcon
    Torrealarcon
    Torrealarcon
    wrote last edited by
    Would it be possible to increase the size of the text showing the distance to the next waypoint—located in the top-right corner—to make it easier to read?
    And also, could the traffic sign in the bottom-right corner be made larger?
    I don’t think either of these changes would interfere with the view of the rest of the screen.
    BMcG 1 Reply Last reply
    • Torrealarcon Torrealarcon
      BMcG
      BMcG
      BMcG
      @Torrealarcon if you want to see a larger version of the distance & time to the next waypoint, you can toggle through the waypoint displayed option on the bar at the bottom of the screen
      tap the bottom bar & it cycles through next waypoint, next Via point or final destination
      for me in portrait mode increasing the size of the skip button & its text by any meaningful proportion can only be done if the size of the next direction box is reduced
      for a long time, many many other people have asked for size of the Next & 2nd Next text & direction indicators to be increased, this has been achieved with V6
      I agree it would be nice if the text for the distance to the next point could be larger but I think it is a compromise,
      the next direction is a more vital piece of info so I would not like to see its size / prominence sacrificed
      again with portrait mode & with dynamic view for V6, the current position indicator is now sandwiched between the traffic & speed signs
      this limits the visible map directly to the sides of the current position compared to V5
      trying to decypher which road to exit at a complex junction requires a clear maximal view of the area around the current position indication
      the view area around current position indication is already compromised with the V6 sandwiching, increasing the traffic sign size would only further compromise the view area around the current position indication in portrait/dynamic mode
      also if the traffic sign roundel is increased then the roundels for the speed & speed limit should also be increased otherwise aesthetically the differing roundel sizes would look odd / jar as they are all related to traffic signs
      further reducing the map area visible around the current position indicator would be a huge negative for me
      the actual layout of the V5 bottom bar including speed indication, menu button/compass/log button provided more map area around the current location indicator, as the location indicator was in a clear space above the bottom bar, not sandwiched
      the new black bar does seem to be a huge piece of screen real estate used very inefficiently in either portrait or landscape mode, especially when compared to the old bottom bar
      you don’t realise how good something was till its changed / gone
      BMcG
      BMcG
      Torrealarcon
      Torrealarcon
      • Elevation profile: cursor that follows the route on the map
      • Question on Beta access
      • Add "Upload File"
      • Totaaltijd veranderd niet
        Gerard Caspers
        Gerard Caspers
      • Device Limit – There Are Limits to My Understanding
        BMcG
        BMcG
      • A to B Navigation with Extra Stop.
