  2. MRA Routeplanner Next Beta
  4. Kaart niet zichtbaar
31 Posts 7 Posters 180 Views 4 Watching
  • Guzzist Guzzist
    @Corjan-Meijerink said:
    https://get.webgl.org/
    Zie je hier een cubus draaien? 🙂
    Me too. On my Android Tablet, I see the linked cubus - but not the maps (only google map).
    On my PC everything is working well.
    wrote last edited by
    #22
    @Guzzist Yours sounds different, because the cube works, so WebGL does run on your tablet. Which tablet and browser is it? And when you open a route, does a notice "The map isn't loading" appear after about 10 seconds?
    Guzzist 1 Reply Last reply
      #23
      Thank you @corjan-meijerink for investigation.
      My Tablet is a:
      SAMSUNG Galaxy Tab S8 5G (Model SM-X706B)
      One UI-Version: 8.0
      Android: 16
      Browser: DuckDuckGo, Version 5.300.0
      By this Browser no map style is beeing presented (only position on white ground) with excaptions: all Google maps are beeing presented. Test WebGL was ok.
      By Browser Google Crome (Version: 156.0.8078.79) everything is working correkt, all map styles and all map layers are beeing presented.
      To compare - my Smartphone is a:
      ASUS ZenFone 8 (Model ASUS_Ioo6D)
      Android: 13
      By this Browser, everything is working correkt, all map styles and all map layers are beeing presented.
      By Browser Firefox (Version 159.0) everything is working correkt, all map styles and all map layers are beeing presented.
      A notice "The map isn't loading" doesn't appear at any device or any browser.
      • Leike Lodiers
        #24
        Heb het zelfde gehad met de Bibliotheek in Librewolf. Kaart niet zichtbaar. Even googlen en zoeken hoe je de webgl aanzet in je browser.
        Om WebGL te activeren in Safari op je Mac, hoef je meestal niets te doen omdat het standaard ingeschakeld staat in moderne versies van macOS en Safari.
        Mocht WebGL toch uitgeschakeld zijn of niet goed werken, dan kun je dit via de menu's controleren en aanzetten. Volg hiervoor deze stappen:
        WebGL inschakelen in Safari (macOS)
        1. Open Safari.
        2. Klik linksboven in de menubalk op Safari en kies Instellingen... (of Voorkeuren... in oudere macOS-versies). Je kunt ook de sneltoets Cmd + , gebruiken.
        3. Ga naar het tabblad Websites.
        4. Scroll in de linker kolom naar beneden tot je WebGL ziet staan en klik erop. (Let op: als je deze optie niet ziet, ondersteunt jouw macOS-versie WebGL al volledig automatisch en ligt het probleem elders).
        5. Aan de rechterkant zie je een lijst met geopende websites. Je kunt hier per website kiezen voor Sta toe of Vraag. Onderin kun je bij "Bij het bezoeken van andere websites" kiezen om het standaard voor alles in te schakelen.
        Wat als het nog steeds niet werkt? (Ontwikkelaarsmenu)
        Als bepaalde geavanceerde WebGL 2.0-functies niet werken, kun je ze forceren via het Ontwikkelaarsmenu:
        1. Ga weer naar Safari > Instellingen... en kies het tabblad Geavanceerd.
        2. Vink helemaal onderaan de optie 'Toon functies voor webontwikkelaars' (of 'Toon Ontwikkel-menu in menubalk') aan.
        3. Er verschijnt nu een nieuw menu genaamd Ontwikkel bovenin de menubalk.
        4. Klik op Ontwikkel > Functievlaggen (Feature Flags) en zorg ervoor dat WebGL 2 (of WebGL-gerelateerde instellingen) aangevinkt staat.
          @Nico-Beerepoot Bedankt, hier heb ik echt wat aan! Dat je geen kubus ziet betekent dat Safari op jouw Mac helemaal geen WebGL kan tekenen, en dat heeft onze kaart nodig. Het ligt dus niet aan je route of je instellingen, en andere sites die WebGL gebruiken doen het bij jou ook niet.
          Kun je Firefox of Chrome eens proberen? Iemand met dezelfde klacht op een andere website had daar succes mee in Firefox.
          Nog twee vragen, dan kan ik gericht verder zoeken:
          1. Welk model staat er bij Apple-menu > Over deze Mac (bijvoorbeeld MacBook Pro 15-inch, 2017), en welke grafische kaart staat erbij?
          2. Heb je macOS Sequoia gewoon via Software-update gekregen, of met OpenCore Legacy Patcher geïnstalleerd?
          Nico Beerepoot
          Nico Beerepoot
          Nico Beerepoot
          #25
          Bouwjaar 2015 vlgs mij
          macOS Sequoia is geïnstalleerd met OCLP maar dat heb ik niet zelf gedaan, dat is voor mij een beetje te spannend.
            Nico Beerepoot
            Nico Beerepoot
            Nico Beerepoot
            #26
            De volgende melding krijg ik in Chrome:
            • Nico Beerepoot Nico Beerepoot
              #27
              @Nico-Beerepoot Bedankt, nu is het duidelijk. Jouw MacBook Pro uit 2015 krijgt van Apple officieel geen macOS meer na Monterey, en Sequoia draait erop via OpenCore Legacy Patcher. Meer mensen met zo'n Mac melden dat WebGL dan niet meer werkt in Safari en Chrome, ook op andere kaartsites. Het ligt dus niet aan je route of je account, en ik kan het vanaf onze kant niet oplossen. Hardwareversnelling aanzetten zal hier ook niet helpen.
              Er is nog één browser om te proberen: Firefox (https://www.mozilla.org/nl/firefox/). Iemand met hetzelfde probleem op een andere website heeft het daarmee opgelost. Je hoeft verder niets aan je Mac te veranderen. Laat je weten of de kaart in Firefox wel werkt?
              Helaas valt er voor mij dus niet heel veel te doen 😞
              Nico Beerepoot 1 Reply Last reply
              • Guzzist Guzzist
                My Tablet is a:
                One UI-Version: 8.0
                Android: 16
                Android: 13
                #28
                Thanks @Guzzist, that's very helpful. Chrome works on the same tablet, so the tablet can draw the map, and the problem is something in DuckDuckGo there.
                I found one way to get a map like yours: the browser's storage for saved map tiles failing, which leaves the map empty without any message. I've fixed that for the next release. I can't test on your tablet, so I don't know yet if this is your problem. Could you check three things in DuckDuckGo on the tablet?
                1. On the white map, do you see the blue line of your route, or only the waypoint pins?
                2. Tap the layers button and choose Michelin or OpenTopoMap. Does that map appear?
                3. Clear DuckDuckGo's data with the Fire button (the flame icon), sign in again and reopen the route. Does the map come back? This closes your tabs and signs you out of websites.
                Until the next release, Chrome on the tablet is the safe choice.
                • Captain Haddock
                  Captain Haddock
                  Captain Haddock
                  #29
                  This post is deleted!
                    Nico Beerepoot
                    Nico Beerepoot
                    Nico Beerepoot
                    #30
                    Tis ff een omweg, maar in firefox doet ie het wel.
                    Bedankt voor alle hulp!
                    Groet,
                    Nico Beerepoot
                      #31
                      Kijk dat is dan toch fijn! 🎉
                      Nico Beerepoot
                      Nico Beerepoot
                      Captain Haddock
                      Captain Haddock
                        Captain Haddock
                        Captain Haddock
                        21
                        36
                        273
                      • Kaart niet zichtbaar
                        180
                      • Google maps
                        Stanisław
                        Stanisław
                        168
                      • RouteXpert display on the map
                        Corrado Miniati 0
                        Corrado Miniati 0
                      • login beta app op mobile
                        Vesparazzi
                        Vesparazzi
                      • Disabling Waypoints?
                        Jannes van Dijken
                        Jannes van Dijken
                      • Has OpenCycleMap been forgotten?
                        Corrado Miniati 0
                        Corrado Miniati 0
