  4. Welke kaart?
Welke kaart?
4 Posts 4 Posters 140 Views 1 Watching
  • Adriaan Vonk
    Adriaan Vonk
    Adriaan Vonk
    wrote last edited by
    Ik zet altijd uit in TomTom en Here. Er zijn meer alternatieven zoals osm. Wanneer of wat is de overweging om 1 van de andere kaarten te gebruiken? Michelin leg ik er trouwens ook regelmatig overheen
    MotoCon John S Parry 2 Replies Last reply
    • Adriaan Vonk Adriaan Vonk
      @Adriaan-Vonk, de overweging is simpel: welke kaart gebruikt je navigatie systeem?
      • Travellexxie
        wrote last edited by Travellexxie
        Mijn standaardsituatie:
        Basiskaart: HERE (apparaatbepaald, want ik heb een Garmin XT)
        Layer: Michelin (Want die hebben van die mooie kleurtjes langs sommige wegen 😉)
        Procedure: kijk of de punten die je toevoegt, of toegevoegd worden, op de lijn liggen.
        MRA Lifetime Gold
          @Adriaan-Vonk said:
          When or what is the consideration to use 1 of the other cards? I also regularly put Michelin over it
          I wish it was as simple as the map your navigation system uses. At least in the Garmin world. One would automatically assume HERE for Garmin exports. But HERE is notoriously imprecise in many areas of mapping. including the accuracy of the maps themselves. Below is an example where HERE (the Black route line) is completely out of sync with where the actual road is (Yellow OSM map road).
          I know this isn't usual, but the fact that it happens at all is disturbing. I've since created dozens of routes using OSM as the base map with zero issues. It's all about having enough waypoints to force the route to be the way you want it.
          I still use HERE as the base map too, but with a lot of caution. The message is to be flexible and understand that you have choices.
          Adriaan Vonk
          Adriaan Vonk
          • Migration of my data
            Solo1138
            Solo1138
            112
          • MRA AI Routeplanner credits
            Bart van de Griendt
            Bart van de Griendt
            87
          • Here Terrain maps style
            Jerry Brok  Wacky
            Jerry Brok Wacky
          • AI Weather forecasts
            Bart 9a 0
            Bart 9a 0
          • Route direct naar Garmin drive
