  4. OSM Routing with MRA
3 Posts 2 Posters 108 Views 2 Watching
  • Brian McG
    wrote last edited by
    As I understand things MRA has its own settings / routing Profile to calculate routes when using OSM as the route calculator
    the way the routing profile for OSM in MRA is currently set leads to some very odd (incorrect/poor) routing choices
    the above is just one example comparing the OSM site to MRA, very often I notice the OSM route in MRA is just weird / illogical
    can MRA not just use the standard OSM Profile settings?
      In your example the OSM route seems pretty logical. Obvious not the shortest. But is it also the quickest?
      Brian McG 1 Reply Last reply
        @M.-Schrijver sorry but no, the example on the left shows the routing as per the OSM web site
        this is obviously the fastest route to pass Reims as it stays on the auto route
        the example on the right is MRA's version of OSM routing, here the preferences for the OSM routing have been adjusted so that the fastest is not the auto route which is incorrect
        MRA has adjusted the routing profile preferences for the OSM routing & they are IMO not optimal adjustments
        this is why when you compare the routing for Here, TomTom & OSM you will see that the OSM takes some very strange paths like the example above
        my question was can MRA not just use the standard OSM Profile settings, what benefit is there to the adjusted profile if it gives strange routing ?
        • Route wordt afgesneden
          Wim Hompes
          Wim Hompes
          Jacob Waterweg
          Jacob Waterweg
        • OSM Routing with MRA
