  3. best format to download
15 Posts 7 Posters 1.2k Views 3 Watching
  • Mike wiruth
    Mike wiruth
    Mike wiruth
    wrote last edited by
    Hello, What is the best format to download? Not only for using offline maps but for transferring to my garmin xt?
    Thanks
    Mike W
    2013 Honda Goldwing
    Bushtec Trailer
    Garmin Zumo XT
    Nebraska
    • Mike wiruth Mike wiruth
      Thanks
      @Mike-wiruth The standard and recommended format is GPX 1.1
      However, this isn't necessary at all for using the MRA Next app offline.
      The important thing is that the maps are available offline and that the routes are synced.
      Everything else works automatically when you navigate with MRA Next.
      If you're absolutely sure you don't have cell service, you can also navigate completely offline right away.
      To do this, simply go to the app's navigation settings, select “Route Calculation,” and enable the “Offline Navigation” option 😉
      BMW R 1250 GS
      DMD-NOR7E 7"
      SPC Universal mount
      Motorola Edge 40 "offline"
      Sena SLR 3
      Sena 50 R
      Mike wiruth 1 Reply Last reply
        When you (still) use Basecamp I would recommend GPX 1.1 (route, track, POI).
        You can then plan the route using the ‘recalculate’ option and afterwards easily check for any discrepancies against the track you’ve recorded. If you send the route and track from Basecamp to the GPS via a cable, you can be sure that everything stays the same.
        I’ve been doing it this way for years and have never had any problems with the route!
        • Travellexxie
          wrote last edited by Travellexxie
          Ok, another sound: I prefer the 1.2 for my XT(1), because it fits exactly to my preferences: the route is based on a track, all viapoints are in the route, pauses you add to routepounts are added tot the ETA, so you know exactly when to tell your wife when to prepare dinner 😂
          MRA Lifetime Gold
          • John S Parry
            Another 1.2 fan here. If you’re running your route on an XT, XT2 or XT3, what you create on MRA Routeplanner is recalculated the same (without fail) on the Garmin.
              @travellexxie @john-s-parry; Do you also use Basecamp as an intermediate step before sending the route to the GPS?
              I understand your reasoning, but when I use version 1.2 and import it into Basecamp, the route I get is just a straight line between the start and end points. The track is correct, but I can’t recalculate the route in Basecamp so that it largely follows the track.
              In version 1.1, when I recalculate the route, it does follow the track (and the waypoints I’ve entered), so I usually only need to tweak a few details!
              John S Parry Travellexxie 2 Replies Last reply
                No.....
                I've tried importing 1.2 routes into Basecamp, and it usually doesn't come in correctly. In the nutshell, I don't think BC understands 1.2 GPX format.
                Regardless of where I create a route (MRA, Basecamp, etc.), I export it as a GPX file. I then do a wired file copy directly into the Garmin/GPX folder on the GPS. A 1.1 route is not guaranteed to recalculate in the GPS exactly as it was created. Sometimes, additional WP's have to be added to force GPS recalculation as intended. With 1.2, it's guaranteed to recalculate as intended. At least, that's been the case with the dozens of 1.2 routes I've exported.
                • John S Parry John S Parry
                  No.....
                  @John-S-Parry GPX 1.2 is a format developed by MRA for Garmin devices. That’s why I suspect it is incompatible with BaseCamp.
                    Ahhh, that explains why the 1.2 format for me will not work. Well, I can coop with the 1.1 format te be used in Basecamp.
                      @a-white-mouse-on-the-motorbike no, why using Basecamp when you have MRA??? Don't come with the story that only Basecamp has the right maps for the XT. That is purely theoretical. The 1.2 is a route based on a track, with only the viapoints, therefore you have no shapingpoints. That is why you get a straight line and recalculating won't help. In this case Basecamp is making a route of its own. I use MRA since 2021 and have never used Basecamp anymore for controlling my routes. Examine the route carefully, if the waypoints are on the grey line and that's it.
                      MRA Lifetime Gold
                        Mike wiruth
                        Mike wiruth
                        Mike wiruth
                        wrote last edited by Mike wiruth
                        @Peter-Zehentreiter Is there any disadvantage to navigating offline? If I have that chosen, will it only navigate off line when there is no signal?
                        Thanks very much for your help.
                        Mike
                        Mike W
                        2013 Honda Goldwing
                        Bushtec Trailer
                        Garmin Zumo XT
                        Nebraska
                          Mike
                          @Mike-wiruth Offline navigation works exactly the same as online navigation—you won't notice any difference.
                          The only difference is that traffic reports and disruptions are not displayed.
                          BMW R 1250 GS
                          DMD-NOR7E 7"
                          SPC Universal mount
                          Sena SLR 3
                          Sena 50 R
                            Yes, that makes sense. All the same, I've tried just in case. After creating a route in MRA, I like viewing it in BC for calculation verification. If it imports/calculates as I intend in BC, it's usually going to calculate as Intend in my XT/XT3 devices. Diagnostics directly on the smaller GPS are more of a challenge.
                            At some point if upgrade to an XT3, you won't be able to use Basecamp to transfer your route to the device. You'll either have to use the Tread app or do the wired file copy. I've never used the MRA Connector, so I don't if that's still an option. Some people are intimidated by the manual file copy, but it's actually quite simple. It gives you complete control of the process.
                            • Travellexxie Travellexxie
                              #14
                              Simple. The Gamin XT was bought before I had a AA screen and mounted on my motorcycle.
                              Nowadays I'm using MRA in combination with the AA screen as my main routescreen. And the Garmin is only used as a backup.
                              • Guzt
                                Guzt
                                Guzt
                                wrote last edited by Guzt
                                For me it is just the opposite. MRA Next is my back up. Never needed it so far.
                                I always optimize any route in the web version before I export the gpx1.1 and import it into BC and optimize it again before sending it to he XT through Drive or directly via cable (which I prefer). Even then, as the algorithmes of the gps and the web version are not the same, recalculation in the gps may come with some surprises. But having the BC track always visible one can interprete the directions properly.
                                Mike wiruth
                                Mike wiruth
                                Guzt
                                Guzt
                                  13
                                  19
                                  145
                                • F006 MyRoute-app Studio - Programm Display Auflösung ?
                                • More personalized dashboard
                                • Change route color
                                • Some minor improvements ;-)
                                • First time version 6 and AA
