  3. Navigation app and the right map
5 Posts 4 Posters 860 Views 1 Watching
  • Pierre c Offline
    Pierre c Offline
    Pierre c
    Hello,
    I'd like to create my trip using MRA on my computer and the Nav app to ride ( on my smartphone Android ) . Is it an ideal type of map to save ?
    Thanks for helping.
    Stefan Hummelink Steve Lynch 2 Replies Last reply
    • Pierre c Pierre c
      Hello,
      Thanks for helping.
      Stefan Hummelink Offline
      @Pierre-c I'm a little clueless what your referring to? Can you elaborate your question a bit more?
      • Pierre c Pierre c
        Hello,
        Thanks for helping.
        Steve Lynch Offline
        Steve Lynch Offline
        Steve Lynch
        @Pierre-c
        I think you are asking which map to use for the MRA Navigation App.
        If that is correct then the answer is that MRA Navigation uses the Here Map, therefore you should use the Here Map when plotting the Route on your computer.
        You donโ€™t stop riding when you get old, you get old when you stop riding.
        • PAD 0 Offline
          PAD 0 Offline
          PAD 0
          Yes, definitely HERE for use with Navigation, and with Garmin devices.
          • Pierre c Offline
            Pierre c Offline
            Pierre c
            Ok. Thanks a lot for your answers . My question was indeed to know on which map to build my route on the computer to avoid a conflict between two different maps between MRA and MRA NAV. Now, I know it's the HERE map... ๐Ÿ˜ƒ
            Pierre c
            Pierre c
            Steve Lynch
            Steve Lynch
            PAD 0
            PAD 0
            • MRA groups
            • POI naming/text display
              463
            • Stemgeluid sterker bij afspelen muziek
            • GPX1.2 & Garmin Tread
              MTC-Zeilberg
              MTC-Zeilberg
            • scenic routes maken werkt niet
            • Folders that can store tracks and waypoints
              martin-phogel.de
              martin-phogel.de
