  4. 3 Devices and only 1 using NN.
7 Posts 2 Posters 745 Views 2 Watching
  • Big Al 1
    Big Al 1
    Big Al 1
    I plan my routes on my iPad using the app, taking the ‘Route Lab’ menu item. I use a dedicated Android device on my bike (using the BMW Connected Ride App) and have the same setup, just in case I need to alter the route when I ride.
    I have just purchased Navigation next, which I only use on my iPhone via Apple CarPlay in my car.
    But now, I get a message complaining I can only use 2 licences and have to log one device out, even though I’m only using Navigation Next on one device. There must be a way round this to stop me continually swapping the licences around. Before I purchased Navigation Next, I had the app on all 3 devices without a problem.
    BMcG 1 Reply Last reply
    • Big Al 1 Big Al 1
      BMcG
      BMcG
      BMcG
      Hi @Big-Al-1 I will try & take a stab at explaining where your problem lies, others with more knowledge of licensing will I am sure be along to give you a fuller & more thorough explanation
      You seem to have 3 devices, the iPad, an Android & an iPhone
      On all 3 devices you use / have installed the MRA app
      When you purchased the Navigation Next licence, each of the installed versions of the MRA app on your 3 devices is able to access the Navigation Next licence, so you have 3 devices each capable of using the licence hence your seeing the licencing message
      I think the simplest way for you to stop seeing this message would be to remove the MRA app from the iPad & instead add a shortcut on the iPad that take you to the browser / web portal of MRA
      • Big Al 1
        Big Al 1
        Big Al 1
        Thanks for replying. I have tried to do what you described, albeit by keep the app on the iPhone and iPad and trying to invoke just the web planner on the Android, via Chrome. All of the routes come up on the Android but as soon as I open a route I get the only 2 user message and the sign-out dialogue. Maybe I did the shortcut wrong!🤷‍♂️
        • Big Al 1 Big Al 1
          BMcG
          BMcG
          BMcG
          @Big-Al-1 yup, it does sound like your shortcut is opening the MRA app on the android rather than the MRA web site
          The web site knows nothing about licensing & devices for the mobile navigation app so you won't ever see such a message if your accessing the web site via a browser
          • Big Al 1
            Big Al 1
            Big Al 1
            In the browser on the Android I type in https://www.myrouteapp/routlab - is this the correct path? ‎The screen comes up with all my planned routes with a welcome that shows it is me signed on. I press on one of my routes and then the menu page shows with the ”good morning screen”, Destination, RX library etc, with the Route lab option at the bottom. If I take that last option I get ‘Account Required’ and a login page. What the heck am I doing wrong?
            • Big Al 1 Big Al 1
              BMcG
              BMcG
              BMcG
              @Big-Al-1 yes the path is good, the path https://www.myrouteapp.com is enough
              your issue is that your browser or some setting on your android is directing you to the mra app when you use that path
              the web site does not have any of the useless annoying pointless guff telling you what time of day it is
              I would try uninstalling the mra app then the broswer should take you to the web site
              • Big Al 1
                Big Al 1
                Big Al 1
                Sorted - thanks guys. I thought I had deleted the app off the Android…..but I hadn’t. I’m not an Android person. Thanks again for your time and patience.
                Big Al 1
                Big Al 1
                BMcG
                BMcG
                • Online map settings
                  MartinW
                  MartinW
                • Real-time traffic
                  Òscar
                  Òscar
                  Andy Nicholson
                  Andy Nicholson
                • HERE map not calibrated
                  MartinW
                  MartinW
                • Myrouteappstay
                  Bé Jeuring
                  Bé Jeuring
                • Navigatie met DMD tablet
                • Show on the maps's button
