  4. 5000km probleemloos!
15 Posts 7 Posters 485 Views 4 Watching
  • Ewout Dundefined Offline
    Ewout D
    wrote last edited by
    Even een positief bericht over de app icm CarPlay.
    10 daagse trip naar de Pyreneeën, iPhone 14 Honda Goldwing met CarPlay bedraad, offline navigeren.
    Het was bloedheet, tot het moment dat de telefoon uitviel door de hitte werkte de app perfect.
    Carplaydraad zit in de topkoffer, denk dat het daarin wel kooktemperatuur werd. Telefoon was bijna niet aan te pakken zo heet was ie.
    1 x viel de app zomaar uit, paar drukjes op de knoppen en het werkte weer.
    Nu nog iets verzinnen om de topkoffer/telefoon wat koeler te houden… En in ieder geval de oude Montana met de tracks als backup meenemen, anders heb je toch een probleem…
    • Hubert Thoringundefined Online
      Hey @ewout-d
      Friends put cool water bottles in the top case and on it the mobile phone, that lasts until the next drinking break, regularly refill and drink, then that fits for people and mobile phones 👋
        I thought Goldwings have refrigarators on board 🙈
        MRA Lifetime Gold
          Mooi om te lezen!! 🙂
            Ewout D
            @hubert-thoring Unfortunately that didn't help, cooling the phone by sprinkling water on cooled it pretty fast! You could see the water evaporating.
            @travellexxie Maybe the 8 cil Chinese boxer will have that, I'll keep an eye on it!
            • Aiello antoninoundefined Offline
              Apparently the crash problem depends on whether you're online or offline... let's hope they fix it soon...
                Ewout D
                Maybe, but I don't think it is that simple. I never had crashes while navigating online. So I think there should be at least another factor. I did have some problems with the app while online navigating, when the iPhone was very hot. It reacted very slowly, did not load the map smoothly. After cooling the iPhone it worked fine. Maybe online navigating puts a heavier load on the phone, when very hot it might cause more problems like the above, or even causes it to crash.
                Aiello antoninoundefined 1 Reply Last reply
                • Travellexxieundefined Travellexxie
                  @Travellexxie just coffee makers and portable toilets! 😀😀
                  • Ewout Dundefined Ewout D
                    wrote last edited by Aiello antonino
                    @Ewout-Dy ou had the tracklog active
                      Ewout D
                      No, I never have.
                        This could be another clue…
                          Ewout D
                          I will try this
                            nomkoundefined Offline
                            Hier en daar wat ventilatie sleuven aanbrengen misschien?
                            En sowieso is een topkoffer geen ideale plek om je mobiel in op te bergen, vooral niet in een snikhete zomer!
                            Kan je nergens op jouw Goldwing een houder plaatsen voor jouw mobiel/Carplay zodat ie wat meer in de rijwind zit?
                            | MRA Gold Member |
                            | MRA Next + Kawasaki Z650 |
                              Ewout D
                              #14
                              Het probleem van oververhitting van de telefoon heeft zich vooralsnog alleen voorgedaan bij extreme warmte, >36 gr. Vorig jaar een soortgelijke trip naar de balkan, daar met 30-32 gr. geen enkele uitval door hitte gehad.
                              Ik heb een 12 Volt ventilatortje liggen, daar maak ik even een aansluiting voor. Wie weet helpt de circulatie net genoeg.
                              Sleuven maken in de Goldwing vind ik een beetje zonde, hoewel dat waarschijnlijk wel de beste manier is!
                              Op het stuur zit ie heerlijk uit de rijwind en wel in de volle zon, daarbij wil ik de telefoon niet op het stuur. Zit de Garmin ook al.
                              • nomkoundefined Offline
                                De Garmin is er wel voor gebouwd om bij hoge temperaturen te werken.
                                Garmin hanteert een bedrijfstemperatuur van -15/+55 graden Celsius.
                                Dit komt omdat Garmin de XT-serie heeft gebouwd om te kunnen voldoen aan de militaire MIL-STD-810-eisen voor onder andere hitte en trillingen.
                                Een mobiel daarentegen is absoluut niet bestand tegen hoge tot extreem hoge temperaturen: 30 a 35 graden Celsius.
                                Als je het vergelijkt met de XT-serie:
                                Smartphone: min. 0 gr. Celsius / max. 35 gr. Celsius
                                XT-serie: min. -15 gr. Celsius / max. 55 gr. Celsius
                                Dus ja, met een smartphone moet je echt oppassen voor de hogere temperaturen!
                                | MRA Gold Member |
                                nomkoundefined
                                Ewout Dundefined
                                Ewout D
                                  Peter Zehentreiterundefined
                                  794
                                  Gerard Wullinkundefined
                                  Gerard Wullink
                                  235
                                • MRA 5.2.1 - 486 CarPlay Display Issue When route started on iPhone
                                  GT JWRundefined
                                • Updated beta! 5.2.1 (486)
                                  white.mouseundefined
                                  224
                                • Unknown symbol
                                  Leike Lodiersundefined
                                • Hoogte meters in Navigatie
                                • MRA en Garmin GPSmap 60CSx
                                • Navigation Next versus Routeplanner
                                  Ron 33undefined
                                  Ron 33
