  4. Layers, stack routes on POI maps
10 Posts 2 Posters 1.6k Views 1 Watching
  • Cleo Offline
    Cleo Offline
    wrote on last edited by Cleo
    What i would like is layers in the planner so that i can stack POI or WP what i would like in multiple days routes.
    My work arround on the moment is that i made, for example, a route map with POI from the cols in the Vosges without any routes and use this to build other routes by make copy's from the POI map. But it would be nice if i can use the POI as layer and above the map were i make a route
    • Con Hennekens Offline
      I really don't understand what your suggestion is. You can enable a POI category on the map, is that not what you want?
      • Cleo Offline
        Cleo Offline
        I make maps with only POI what i like to visit, like i also do on Google maps. So i see all interesting WP in a certain area. The i use this to make a route os routes. I see were all the interesting WP's are without constant enable or disable the POI category's. This i al ready did. If i have to enable disable categories for every time to create in an area you have to do it muliple times. So on this moment i make a basemap and copy it constant
        • Cleo Offline
          Cleo Offline
          It's like Photoshop were you work with layers to build your foto's, so why i can't use this system to build my travel routes. It's a diferent vision on make routes
          • Cleo Cleo
            @Cleo Here is how I would do it.
            • export your "Route with only POI" to gpx
            • leave your pseudo-route open
            • import that gpx file as personal POI library
            • activate the set a checkmark and click the profile icon (turns into X)
            From now on ALL your POI will show on all routes, in the planner as well as during navigation 😉
            • Cleo Offline
              Cleo Offline
              I will take a look at it
              • Cleo Offline
                Cleo Offline
                @con-hennekens So you also miss layers and found a way around it
                • Cleo Cleo
                  @Cleo, No, that's just how personal POI work 😉
                  Cleo 1 Reply Last reply
                    Cleo Offline
                    Cleo Offline
                    @Con-Hennekens I don't want to use my personal POI but a selected view what is available but on multiple days. If a ad one extra POI on the layer it's direct visible on all routes, now i have to change all my finished routes.
                    But it can that you don't understand how handy layers are because you not used them.
                      I don't use POI at all in such a case. I just put a VIA point at all places I want to visit. That seems very handy to me. That being said, I think we can expect a lot of improvement in the handling of POI in the next web-planner (which unfortunately will still need a lot of time).
                        300
                        227
                      • No location in Android Auto ! App unusable !
                      • How do I remove an old device?
                        Bruno 7
                        Bruno 7
                        244
                      • Volume not restored after announcement
                      • New update 5.2.1
                        28
                        1.8k
                      • Share POIs with Google Maps
