  3. weekend trip and my results
9 Posts 3 Posters 1.2k Views 2 Watching
  • Bouke Ent Offline
    Bouke Ent Offline
    i made a small trip to DE/LUX.
    planning was based on TET. that is already a test for MRA. i did import track in MRA for B and LUX. In short long way but i could make a MRA believe it would work in OSM.
    first day on highway to B and then follow TET. result it was not so bad. Here maps are not OSM and navigate as track does also not 100% work. even "witte" line is not the same as track. but oke it was 95% ok.
    second day tour in luxemburg. must say "witte" line was good and blue line was 95% willing to follow.
    last day i made route in kurviger pro v1 app and it was a great ride but in MRA Next the "witte" line was perfect but Here/blue line was an other way. it was 50/50... 50% here was right road was not allowed but 50% here was wrong.
    the i wanted to go home frome brabant to alkmaar. MRA Next offline could not make a normal A to B route from reusel to alkmaar..... so i had to switch to TT and it find also offline route to alkmaar.
    in sort if i stay on Here maps it is perfect, if offline then it not always works...
    • Hubert Thoring Offline
      @Bouke-Ent , It is perfect because it also works very well offline, but for that you must have previously loaded the offline maps best via WLan ..!!
      iPad 9. Gen iOS 26.6/ iPhone 16e iOS 26.6/ Navi iPhone Xr iOS 18.7.10 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
        Test in airplane mode so without network ..
        That also goes very well, a route planned in the app so offline ...
        Bouke Ent 1 Reply Last reply
        • Bouke Ent Offline
          Bouke Ent Offline
          i have all maps on my phone. it was just a AtoB route to home but he could not calculate a route, i was outside on a road. no idea why. i had this in the past a few time, maybe in 10% of the cases i make a AtoB route. when i am on vacation and i have that problem then i just ride a few km and try it again and the it normaly work. for calculation i had no exeptions all allowed. i did just want to go home in a fast way that is why i just took TT and solved the problem.
          LE DIZES Freddy 1 Reply Last reply
            Bouke Ent Offline
            Bouke Ent Offline
            @Hubert-Thoring said in weekend trip and my results:
            reusel is a small town in the south of the netherlands near belgium border in province brabant. you use brussels.
            • Bouke Ent Offline
              Bouke Ent Offline
              this offline problem is very minor so in all MRA Next worked great for me. As is said i did drive parts of the TET and in OSM they are perfect. In Here is a puzzle on a few points on the route. But is was very happy that the white line did match perfect the TET track. i have beside MRA Next a track viewer so i could check the white line.
              • Bouke Ent Bouke Ent
                LE DIZES Freddy Offline
                LE DIZES Freddy
                @Bouke-Ent can you tell me how is your MRA when tout are on the TET
                • LE DIZES Freddy LE DIZES Freddy
                  Bouke Ent Offline
                  Bouke Ent Offline
                  @LE-DIZES-Freddy said in weekend trip and my results:
                  As i said i did 2 part of a TET. 1 east belgium from dutch border to luxemburg border. 2 in luxemburg south from begium border to echternach.
                  both part ar +95% paved. OSM could find the total part. so i imported the tet track in MRA in OSM. then i made it my my part that i did want to drive and did export it as track. that track i loaded back in MRA. In MRA Next i just selected de track and said navigate. blue line was not correct but the white line was correct. i did follow the white line.
                  you can load directly de tet track in that way but then you can not change start en finish.
                  MRA Next uses Here map zo blue line is not working.
                  but this belgium and luemburg part is +95% paved so you can do it. my test was how it works with a OSM based map route/track.
                  in some parts of even europe the Here map is not so good and then OSM is the only maps that work. I have as backup a OSM based app but i want to stay in MRA/MRA Next.
                    LE DIZES Freddy
                    @Bouke-Ent merci
                    LE DIZES Freddy
                    LE DIZES Freddy
                    • How to share route with another member.
                    • Route doesn’t recalculate to my destination
                    • No navigation instructions
                      730
                    • Offline navigeren
                    • Ideetje voor kaartthema van Google Maps
