  2. New Users' corner
  3. New User from the UK
8 Posts 6 Posters 1.7k Views 2 Watching
  • Ken Clarksonundefined Offline
    Ken Clarkson
    Hi, Ken here, new to MyRoute App and to the forum. I ride a Triumph Tiger 800 and like to tour Scotland when I can. I'm just past my mid sixties and retired.
    I've done a few routes and exported them to my Garmin 390 via my PC. On the Garmin it shows straight lines and all my waypoints .As a track it follows the route correctly but no waypoints,is this normal?
    Nick Carthewundefined Hans van de Ven MR.MRAundefined PAD 0undefined 3 Replies Last reply
      Jack van Tilburg
      Welcome Ken!
      Unfortunately that is indeed normal.
      Route export actually only works well with the ZumoXT.
      It is best to export the track and convert it in your device.
      Disable recalculation. To see if you do not accidentally deviate from your route, it is best to make the original track visible on the screen.
      Ken Clarksonundefined 1 Reply Last reply
      • Ken Clarksonundefined Ken Clarkson
        Nick Carthewundefined Offline
        Welcome to the forum @Ken-Clarkson.
          @Ken-Clarkson
          Welcome @Ken-Clarkson to the forum
            Ken Clarkson
            Thanks for the replies guys
              Welcome Ken!
              Ken Clarkson
              @Jack-van-Tilburg Sorry for the late reply, I recently exported a route to my zumo 390 and followed the track. It worked perfectly but it was strange having no waypoints. I didn't disable recalculation and it still worked.
                Jack van Tilburg
                That's right.
                You let the Zumo create a route based on the track. This route contains no route points. If you deviate from that route, with recalculation enabled, the route will be recalculated and then go to the end point according to the Nav settings and not according to the track.
                  PAD 0undefined Offline
                  PAD 0
                  @Ken-Clarkson I use a Zumo 390 and can export routes created in MRA to it with no problem whatsoever, including the route accurately following roads and with all waypoints intact, and have put them to use with complete success. In the Connector, be sure to select .gpx 1.0 as the file type, not .gpx 1.1. In my experience, using 1.1 files will result in those straight lines on the 390 - I think these are best left to the Zumo XT and, possibly (though I'm not certain) the 396 and 595 models.
                  I hope this helps. Please let us know how you get on
                  Jack van Tilburg
                  PAD 0undefined
                  PAD 0
                  Ken Clarkson
                  • Please write in English.
                    Nomko Nomdenundefined
                    Nomko Nomden
                  • positie indicator meerdere keren ver van de route
                    Adrian Avramundefined
                  • Straßensperrungen werden nicht erkannt
                    Axel Härtlundefined
                    Axel Härtl
                  • How to navigate a track?
                    Martin Wilckeundefined
                    Martin Wilcke
                  • Two Device Limit
                    Nick Dawsonundefined
                    Nick Dawson
                  • Flitsmeister
                    Lex.Kloet.RXundefined
                    Lex.Kloet.RX
                    1.3k
                  • Bookmarking RX routes / collections
                    Martin Wilcke
