  3. How to stop MRA asking to add to favourites to route?
22 Posts 7 Posters 3.9k Views 4 Watching
  • Malcolm Bradleyundefined Offline
    Malcolm Bradley
    I used MRA this morning after the most recent update and I found it really annoying as, when I passed several locations a message appeared asking to add that location to my favourites...!
    Why?
    If I wanted to add a place to my favourites I would do it myself.
    How can I stop this happening - does anyone know?
    Many thanks,
    Malcolm
      @Malcolm-Bradley, does this look like the window presented to you?
        Malcolm Bradley
        That's it. It covers almost half the screen in portrait mode and is impossible to get rid of whilst travelling so I have had to stop, drag it to the bottom or exit the app then restart the app to get rid of it 😞
          In that case you definitely have something “touching” your screen.
          While navigating I’d recommend using the screen lock. Just open the menu to see the option 😉
            It certainly also helps to clean the display including the edge of the case... to avoid touching a display by such.
            iPad 9. Gen iOS 26.4.2/ iPhone 16e iOS 26.4.2/ Navi iPhone Xr iOS 18.7.8 / PC mit MS Win11 /❗️MyRoute-App im Cradel und Remotek-One❗️ Info zu MRA & Remotek One
            • richard 3vundefined Offline
              richard 3v
              Well I'm with @Malcolm Bradley on this one.
              I also tried to use the new app yesterday and came across the same issue.
              A complete pain in the arse.
                I think I know what I can do to slightly prevent this.
                That said, it really is something with the device screen sensitivity registering phantom gestures. The app even had a dedicated feature to prevent this completely when you are for example driving in the rain 🙂
                richard 3vundefined 1 Reply Last reply
                  richard 3v
                  Thanks, please let us know when you have implemented this fix 👍
                    Will be in the upcoming update 5.0.1 - just made the change and it will be included in the update.
                      richard 3v
                      Thankyou
                        @Corjan-Meijerink said in How to stop MRA asking to add to favourites to route?:
                        That's exactly what I was thinking...
                        @Malcolm-Bradley, I recommend a thorough cleaning of the screen, but it might also be broken.
                        The reason you do not have a continuous problem with other apps, might be that the MRA app actually has a screen covering function for long-pressing an area (add a waypoint). Not many apps have that.
                        • David Rudgleyundefined Offline
                          David Rudgley
                          Don't you think that we'd realise that something was touching the screen? and your first thought that it was the user causing the problem 🤷‍♂️
                          Android Pixel 9 Pro XL
                          TomTomGo as backup
                          KTM 1290 Super Adventure S
                          Quad Lock + Phone +Carpuride W702
                          KTM 790 Duke
                          Quad Lock + Phone
                          • David Rudgleyundefined David Rudgley
                            @David-Rudgley, to whom are you targeting your comment, and what do you really mean by it?
                              Malcolm Bradley
                              Many thanks all, there was definitely nothing touching the screen, the screen is clean, unbroken / uncracked and has an unbroken / uncracked screen protector covering the screen.
                              It was raining at the time but I don't see why the app should be susceptible to rain as I'm sure most people using the app live in countries where the screen gets wet.
                              Hopefully the update when implemented gets rid of this really annoying feature. It isn't needed and as someone earlier wrote - a real pain.
                              I'm not really sure, as this is an app targeting bikers predominantly, who thought introducing annoying pop-ups whilst riding would be a good thing.
                              Other than this, I'm happy with the app 🙂
                              • Malcolm Bradleyundefined Malcolm Bradley
                                @Malcolm-Bradley, no pop-ups are programmed to annoy bikers... 😉
                                If you were driving during rainy conditions, that explains a lot. It is not the app that is susceptible to rain, but your phone (any phone) is. This is due to the way phone screens work: capacitive. A little explanation about this (which is mainly about LFDs but works for phones as well) is added below this message. Usually the common dedicated navigation devices use resistive touch technology. The XTs are capacitive though. All smartphones I know use capacitive technology, and are therefore sensitive to raindrops.
                                An already existing feature to prevent this has been implemented long time ago. While navigating, you will find a "lock screen" function in the settings (three dot menu). This makes the screen insensitive for raindrops (and finger touches 😉 ) but presents a small unlock button to unlock the screen again. The chances of a raindrop catching exactly that unlock spot is of course much smaller than it messing with the whole screen.
                                The newly introduced feature to help against rain messing things up, changes the way you can add waypoints or set a destination. That can still be done by a long-press, but the map needs to be panned (moved) a bit first. That is usually what you do when looking for waypoints to add or destinations to set anyway. The chance of a raindrop first moving the map and secondly long-pressing a spot are probably slim. But it is no guarantee rain will not mess up anything.
                                  Malcolm Bradley
                                  Thanks for your reply Con but...this has never happened before the most recent update. I've been using MRA in the rain for the past 2 years or so without ever having this happen.
                                  Con Hennekensundefined Brian McGundefined 2 Replies Last reply
                                    @Malcolm-Bradley, I must admit I am a nice-weather-biker. I have seen my share of rain, but V5 not yet 😉 . However I cannot think of any reason why this would be different then it was in V4...
                                      Brian McGundefined Offline
                                      @Malcolm-Bradley it happens to me often enough due to rain & because I have my phone orientated quite horizontal/flat I often have to resort to the Lock Screen" function
                                      this is NOT a v5 phenomenon
                                      maybe the angle you mounted the phone was a little different to normal, maybe you were doing slightly slower speeds so there was more rain/water on the screen
                                      Normaly navigate Routes in Offline mode with Offline Maps
                                        #19
                                        Oh and to add to it, we added a new feature where tapping a POI on the map triggers this feature too as opposed to v4 where we only had a long press feature anyway.
                                        Thus is makes sense that undesired touches can now be triggered more easily. As said! 5.0.1 will include a method to prevent this automatically along the existing “lock screen” feature.
                                          Okay, so apparently there actually IS a reason why it is different in V5 afteral. 😉
                                          (which apearently I forgot about...)
                                          This also explains why @Malcolm-Bradley was experiencing this mainly at locations of interest.
                                          To Malcolm, I am sorry to have bored you with my incorrect assumption 🤣
                                          David Rudgley
                                          richard 3vundefined
                                          richard 3v
                                          Malcolm Bradley
                                          • New beta! 5.1 (457)
                                          • Te veel problemen
                                            Lex.Kloet.RXundefined
                                            Lex.Kloet.RX
                                            689
                                            Axel Härtlundefined
                                            Axel Härtl
                                            2.3k
                                          • DMD T665 Phone + MyRoute App?
                                            Martin Wilckeundefined
                                            Martin Wilcke
                                            1.6k
                                          • BDR Route GPX Support
                                          • Raul from Argentina
                                            Leike Lodiersundefined
                                            Raul Arteagaundefined
                                            Raul Arteaga
                                            1.7k
