  4. Changing route algorithm
4 Posts 3 Posters 2.7k Views 1 Watching
  • Rae Sewellundefined Offline
    Rae Sewell
    Hi all, is it possible to change an existing route from Tomtom routing to Here routing on the phone app?
      @Rae-Sewell, When you start navigating a route which was planned with TomTom maps, you will be notified and the route will be started in "route as track" mode in order to maintain the original route as much as possible.
      In Planning mode, when you edit a route and save it, it will be automatically set to HERE, since the in-app planner only offers that single map.
      • nomkoundefined Offline
        @Rae-Sewell
        What do you want to change? The route itself or the map?
        Basically you can change/modify any route in the Next app but this is somewhat kinda tricky and takes up more time and effort than changing it in the online routeplanner itself.
        If you want to change the route itself, best is to do it in the online routeplanner since you have a much better overview and more screen space. And it works much more efficient than using the Next app.
        Most users who change routes in the app will do this during a ride or during a stop/break.
        | MRA Gold Member |
        | MRA Next + Kawasaki Z650 |
          Rae Sewell
          Thank you.
          nomkoundefined
          Rae Sewellundefined
          Rae Sewell
            Peter Zehentreiterundefined
            733
            3.6k
            Massimo Cardoneundefined
            Massimo Cardone
          • Hi, new UK based user.
            Albert van den Elsenundefined
          • 5000km probleemloos!
            stuart marrittundefined
            stuart marritt
